Question about Kenmore 24 in. 16302 Built-in Dishwasher
Kenmore Elite - Flooded bottom
Hi, my dishwasher is flooded on the bottom,
i emptied out the soapy water after a run, checked the filter and it looks fine.
i did another run and its flooded again, it seems not to go higher that the bottom of the door opening, but its still flooded at the bottom?
do you think it may be a clogged line, or some kind of pumping problem?
  • 3 more comments
  • j-sun Nov 20, 2007
    no suds, just water, about 2 inches high of used soapy water, like its not filtering out of the washer. How can i make the water go out like it use to?
    the guest comment was me, i didn't realize i wasn't signed in. but i can get the flooded water to drain out, any other suggestions?
  • Hughman2 Jul 06, 2008
    I have the same problem...water will not fully drain and there is a buzing sound during the drain cycle. I check the drain line and vent and they are clear.
  • lyntintin Jan 28, 2009
    My Necht dishwasher started beeping and the 'E' symbol shows ,the machine also flooded and could not drain,I emptied it by hand , but every time it will start again it just floods again . I have been unfortunate in having all Necht appliances with my kitchen . They are total rubbish ,the flooding problem with the dishwasher is common ,and the aftersales  non existant , reading other comments on the net , I feel the only option is to get rid as soon as I can and not waste any more money on repairs,
  • Anonymous Mar 14, 2014
    there is water on the bottom of dishwasher and it will not come on. the breaker is fine there are no clogs. the door latch works fine also. what could it be?
This is a necht dishwasher under one year old the problem is as follows. machine switche on make the normal noises to start with after about two minutes it beeps for about twenty seconds machine then stops. The water does not seem to be coming into the machine but a small amount of water does come in at the botom of the machine ie. where the waste is. Please can you help.
Thanks
Posted on Oct 06, 2008
  • 248 Answers
Is it full of suds? If so, someone put manual dishwahing detergent in it. Allow to fill and open and add a splash of wesson oil. Run unit. This will knock down suds. Allow to run thru cycle to clean out.
Posted on Nov 19, 2007
  • Gerald Griffin
    Gerald Griffin Nov 20, 2007
    If this model has a remote drain pump it may be blocked or inoperative. Does the drain hose attach to the main pump underneath in center, or to a small electric motor driven pump?
    If a remote pump, remove pump and check for blockage.
My dish washer flooded and i have have two flashing lights on. slened the filters and took off water supply and re attached still no change.Book says it is on protection from flooding. how do i sort out...
Hi Tony,
I'm going to need some more information from you, so please post back with the following details:
1. Brand/Model of washer
2. You said it "flooded" - was water escaping from the machine? Where? From underneath or from the door area?
3. Is there still water in the bottom of the wash compartment now?
4. You said you cleaned the filters - were they blocked up?
Hope to hear back from you asap. Keep the water supply turned off for the moment.
Regards,
BElectric
Nov 05, 2010 | Dishwashers
17379 - The fill water does not shut off - even with the door open. Flooded the room.
Fill valve is stuck open and must be replaced. Is behind bottom panel to the left where the water line attach's.
Oct 27, 2010 | Kenmore 24 in. 17372 / 17374 / 17379...
Will not drain
check for a dirty and clogged filter, and make sure pump is running. check float switch at the bottom of the unit and make sure bottom tray is not flooded.
Mar 07, 2010 | Jenn-Air 24 in. JDB1270AW Built-in...
Dishes are coated with soapy film after full wash cycle
The problem is not your dishwasher but rather the water going into it. Hard water when heated up in a dishwasher dries with calcium and magnesium spots(often looking like a white residue). There is a product out there just for this problem and its called the dishwasher filtration system. It filters the water going into your dishwasher solving this problem once and for all. It is very affordable(like 70 bucks) and has a money back guarantee. You will not want to return it trust me. after the first load you will be amazed. www.dishwasherfilter.com is where you can get it.
Jul 05, 2009 | Kenmore Dishwashers
Error code e4 on kenwood kdw12st3a dishwasher too much inlet wate
HI there,
I have had the same problem as most of you. I seem to have fixed it by
1. Bail out all the water from the inside
2. Remove the filter and 2 x mesh pieces.
3. Continue to bail out the water from the filter well.
4. You will probably find pieces of food or fat/debris in the bottom of the well. Remove these.
5. Tilt back the dishwasher at 45 degrees for 30 mins or so to drain and dry the flood sensor.
6. Boil a kettle and pour it down the well. Immediately put the dish washer on a eco wash (no tablets or anything) with half load (ie half water) and this will ease the water pump.
7. Let the dishwasher run its cycle.
8. Clean the filter again and the filter well.
It sounds quite long winded but with a £250 item you need to take care of it. Make sure you rinse most plates before loading in the future.
Hope this helps!!!
Good Luck!!!
neo
Mar 01, 2009 | Kenmore Dishwashers
Bosch slimline dishwasher flooded kitchen
Your debris filter needs to be cleaned. It is found under the dry bar in the bottom of the tub. It looks like a plastic mesh and you can usually remove it to wash it out if not use an old toothbrush etc... this should help.
Jan 11, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
What does F20 mean
Ok, I found 2 solutions for this problem, I tried the first one,and it really seemed to work, but I think I will do the second one too. First, if you have metal flood safe hoses, you need to look for debrisblocking the filter at both ends. I kept checking the screens at thewasher end and not seeing anything, but there was debris located at thewater supply end, stuck in the flood safe device that is in the metalhose. Also, Flood safe hoses say to turn the water on to fullpressure, but sometimes that can activate the flood safe device, soonly turn your water supply on half way. Make sure that the hoses areon right as well, the flood safe device needs to be at the end with thewater supply, not the washer end. You will be able to see the device(it looks like a little sieve) inside the hose.
Another cause of this problem can be the filter IN your washer, itis located in the front just under the front bottom removable panel. If you have a pet in the house, definitely check this out, a lot ofhair gets stuck in that. Just unscrew the front bottom panel, and thenit is right in the middle at the bottom, a cone shaped filter. Get atowel, because there will be water in there, too. Check out this linkwithpictures: http://enginerdandwife.com/2007/03/kenmore-elite-h3-washer-error-code-hf.html
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
SMEG INTEGRATED DISHWASHER FLOODING
Are you saying it overfilled and flooded out, or did it empty onto the floor?
Nov 18, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Water flooding out
Hi KellyW,
The dishwasher drain hose may be clogged.  When the dishwashr starts up can you hear the water running into the Sink faucet drain. If not inspect the hose that attaches to the Sink Drain for restrictions.  Also in the bottom of the dishwasher you should have a filter.  If this filter is clogged you cannot expel water.  Clean the filter.
Oct 23, 2007 | Asko D1776 Stainless Steel Built-in...
Kenmore 24 in. 16302 Built-in Dishwasher Logo
543 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
