Remove the front panel on the dryer, get the old belt and take it and the model number into your local shop to get the proper belt, put the new belt around the drum with the groves towards the drum, replace the front panel. on the lower part section of the dryer on the back there will be a panel you remove it see the motor, reach in and place the belt around the pulley on the motor then carefully force the tension idler down towards the floor till you can place the lower section of the belt into the pulley on the tension idler and release the idler. you can now run the dryer, as the drum turns the belt will place itself. hope this helps.
