Question about Black & Decker Hedge Hog 22-Inch 2.8-AMP Dual-Action Hedge Trimmer #HS1012
Need the handle for B&D power sprayer GSP014, cant find anything on line. ANY HELP? jOE
  • 47 Answers
Look at www.toolpartsdirect.com . they have a parts breakdown with part numbers for this.
i dont know where you are but its a us site.
copy and paste the part number for tha handle into your browser , it should come up with results.
Posted on Jul 19, 2009
Is there someplace to buy a whole rubber washer repair/rebuild kit for a Roundup 4gal BP sprayer? It's square and was built in 2005 unlike the rounded newer ones. thx joe
I've found buying one thats too big and cutting it to size and shape works best on my sprayer. You could go for a sheet of rubber and cut it all out with an exacto knife too.
May 13, 2014 | Roundup Garden
My water pipe to my kitchen two-handle faucet, after it thawed out all I get is a small steam on hot & cold side. How do I fix this?
Could be a sediment clog in the sprayer head. Remove sprayer head from flex line and clean out the end that attaches to the water flex line.
Mar 16, 2014 | Price Pfister Side Spray With Hose and...
Making a shuddering noise and cant seem to get full power
Make sure screen where hose attaches is clean for proper water flow to sprayer, make sure you have good flow from hose supplying water to sprayer. Turn water supply on, and hold handle down to spray, before turning on and see if it helps.
Jul 14, 2011 | Karcher Garden
Have single handle faucet with pull out sprayer. Whe I turn handle toward the hot side the water pressure drops almost to a trickle. Turn to cold and it is ok. What is problem and how to fix Thanks
Check under the sink at the valves that the hot and cold water lines are connected to. See if the hot water one is turned on all the way.
JOe
Mar 02, 2011 | Blanco Plumbing
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
Sink sprayer hose makes noise
hello, you may have a air pocket in the line try shutting of the water supply and then sqeeze the handle and slowly turn the water supply back on with the hose handle squeezed on till the air is forced out, hope this helps
Jun 07, 2010 | Moen 87530 Touch Control Single Handle...
My hoover steam cleaner will not put down the soap solution? Any suggestions!
The line may be clogged.
If you look in the tank see anything blocking?
No? Okay moving on. You may need to remove a cover or covers.
Find the lower end of the line / tube.
Carefully remove the line.
Now with safety glasses on take a can of air, and blow the the line & sprayer out. Replace all parts you removed.
In the tub, shower or outside. Add vinegar & distilled water to tank let set for 1 hour then see if it will work. Let the water go down the drain or outside. If this don't work you may have a bad sprayer switch.
Please let us know.
May 18, 2010 | Hoover F5842-9RM Steam Vacuum
I have an older delta faucet. Sprayer does not work well.
i believe the faucet shaft,..they usually are on delta models i've worked on,........your best to get a full rebuild kit for this and do the whole thing when you've got it down,.....good luck, cracklin joe
Jan 10, 2010 | Delta Faucet #RP320 Divert Assembly
I have two 428 solo back pack sprayers both of the pumps have crackes in them where do I get parts. Help!!!
i have 428 with a broken pump handle. the solo co. has some parts.their ph. no. is 757-245-4228,i talked to a young man @ ext.352,name is shawnatin.if you can't get the parts,i would like to offer you $5.00 a peice for the handles & shipping cost.just snapped today while working in my yard.
May 02, 2009 | Solo Backpack Sprayer 5 Gallon, Model# 428
Behringer pmp2000 europower no sound
Probably the power amp has arced and popped a lot of components.
When teh amps go usually the final pwer transistors, their drivers and sometimes even the power supply gets zapped.
Check the output of the preamp at the inserts for the final amp with headphones to see if anything is coming through.
Jan 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
Black & Decker Hedge Hog 22-Inch 2.8-AMP Dual-Action Hedge Trimmer #HS1012 Logo
314 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
