Question about Dell UltraScan P1110 21" CRT Monitor
My screen sayin signal cable disconected
Hey my name is Sarah, i need help trying to fix the problum signal cable disconnected...can you help
my Email
loveisnotforme@live.com
If you are using an lcd monitor, make sure you have connected the vga (screen cable) properly and tight both on the tower and your monitor. if its crt monitor then make sure the vga cable is tightly connected to the tower on the female connector
Posted on Jul 20, 2009
There is a thin wire cable with a spring inside unit witch is the cable is broken where do i get a new one
FOrn get it, PEople are trowing them out, Where i live , Ones that work no one want them any more,
Nov 26, 2012 | Technics SL-MC7 110-Disc CD Changer
I disconected my receiver when connecting back did not work never acquire signal
The satellite in cables play a big role in a receiver getting signal. Since they were disconnected, verify the cables are both hand tight and everything is plugged in.
If the satellite was working before, but isn't after disconnecting there may be a connection problem in the line. At that point verify all the cables are tight, and you can also try swapping the Sat In cables around. The Sat In cables have to be in the correct port to work. Let me know if the problem continues!
Tommy Faust
DISH Social Media Representative
May 16, 2012 | DISH Network 322 DTV Receiver
How do I connect my hp laptop to my lg LCD tv? I've tried plugging in the hdmi cable to both but my tv keeps sayin ' no signal' please help meeee :(
you need to select the screen you can use because most of laptops don't support to use both screens(laptop screen & monitor / plasma tvs that have VGA port) at once.. you can select your screen by check on F function buttons on your keyboard ...you can identify that button easily because it shows two screens on it just press that button you will choose the screen you can use.
Mar 06, 2012 | LG Televison & Video
I have a dish network 322 will play in one room, but 2nd room it continues to try to acquire a satellite
Hey there, my name is Cheri Torres with DISH Networkcustomer service. I came across your post and wanted to see if I could help.When one of your televisions are working fine and the other is trying to acquire satellitesignal there could be a few different things going on such as a bad satelliteinput on receiver, bad separator etc. The first step you are going to want totry is performing a hard reset by unplugging your DISH Network receiver box for10 seconds then plugging it back in. If you have tried the hard reset the nextstep would be to check your entire cabling make sure all your cables are tightand secure coming from the receiver and running into the wall. After all thecables are checked you are going to run a check switch test. In order to run aCST you will need to press the menu button then 6(system setup),1(installation), then 1(point dish). Once you are in the point dish screen youwill select check switch, then on the next screen select test. Allow the testto finish then you can proceed to cancel out of all the menus. Once you are outof the menus you will see the satellite trying to acquire the signal againallow this to finish. In the case that none of these steps fix the issue youare going to need a technician to go to your home to fix this issue for you inperson. In order to get a tech set up you can call our customer service line at1-800-333-3474 or you can email me with your account information and phonenumber and I can help you get a tech set up, my email isCheri.Torres@Dishnetwork.com. I hope you find this information useful if youneed anything else feel free to post back here or email me.
Jan 11, 2011 | DISH Network 322 DTV Receiver
It sayin no input and goes input into sleep mode
That means the monitor is not getting any signal from the computer. Check the video cable, make sure it's not loose or disconnected.
Dec 21, 2010 | HP Computers & Internet
I have...my own facebook login...but i have forgotton my usename....an my Gmail account name. my name is sarah wood...my old username was tiger6967@hotmail.com please help.. an email...to...
use tiger6967@hotmail.com as the user name. Username is usually the email address unless you register using a mobile phone in which case your mobile number is your username.
Hope this solution has been helpful?
Aug 23, 2010 | Computers & Internet
Disconetion errors on my ps3
If you're using a router, you could be having compatibility issues between the router and your PS3. When I first got my PS3, I had the exact same problem--it simply wouldn't stay connected to the Internet, no matter what I did. Then I changed to a different router, and the problem was fixed.
May 09, 2009 | Video Game Consoles & Games
I have a new printer now, and just started having problems. It's not printing I have checked everthing as well tried everything please help. You can email me egordin@comcast.net and tell me...
plz tell me what type of problum u have
did u install its driver properly
did u install its cortridge properly?
all cable connected properly
what is the name and company of ur printer
May 01, 2008 | Office Equipment & Supplies
Messege errors
It sounds as though there is an email stuck in your outbox. I don't know which email program you are using, but you should be able to open your email program, wait for the error messages to appear, close the error messages & delete whatever is in your outbox.
Nov 13, 2007 | Microsoft Office Outlook 2003 for PC
What is "The ground"
Do not repeat DO NOT disconnect the Ground or Earth of any appliance, potentially lethal voltages can occur under fault conditions that the ground protects you from.It is a connection to a bonding point of your nearby mains distribution transformer. If your problem is hum then you could try using a balanced screened cable between your TV & audio units with one end of the screen disconnected (This is normal practice in studio's and broadcast situations) HAMAR
May 17, 2007 | LG 42PX5D 42 in. Plasma HDTV
Dell UltraScan P1110 21" CRT Monitor Logo
142 people viewed this question
Alun Cox
