Question about Turbo Air TSR-49SD Stainless Steel Commercial Refrigerator
I want to know the wire connection to compressor
  • 614 Answers
MOst common are left to right start,common .run. Russ
Posted on Jul 19, 2009
I have a oil less compressor 120volt,2.5amp,60hz,1phase,100psi tank that has 3 wires a black,white,green..the black an white connect to a panel inside the plastic cover of the compressor,the green isn't...
Connect green wire to any steel surface so that the body of the compressor is grounded.
Otherwise, join another wire to the green wire and extend the length to a surface that can ground the compressor body.
For safety, a motor must always be grounded.
To test the ground, connect power to compressor, and test hot black wire to steel body of compressor and to steel housing of motor ... if there is a positive ground the test will show 120V.
Tape tester leads to wood sticks for safety... do not touch anything made of metal... stand on completely dry surface... never stand on bare ground... stand on boards and wear dry shoes.
Gene
Aug 15, 2014 | Hardware & Accessories
How to wire in new hard start
It's very simple to install a 3N1 Supco Hard Start Relay, Some refrigerators have a run capacitor located on compressor or mounted nearby. It will be important that you use the run capacitor in with the 3N1 Hard Start. Here is a Photo of the=> URCO810_3_N_1
The instructions come with the 3N1 Hard Start Relay. Can you please post the model number of your refrigerator here so I can look up a wiring diagram? Look around the fresh food section door frame for your model number. I do need to know so we can get the right run capacitor in the 3N1 hard start circuit, Thanks Sea Breeze
Jan 30, 2013 | GE GSS25LGP Side by Side Refrigerator
A/c compressor keeps blowing fuse
Disconnect The AC compressor clutch, does the fuse still blow.
Oct 21, 2012 | Cars & Trucks
On my porter cable 6 gallon air comnpressor need to know where the red black and yellow wires get plugged into
there always three wires in the power cord, the green/yellow stripe wire is for ground connection,which doesn't needed to modify.
One of the other two wire is directly connected to the power plug , and the other connects to the contact point at the pressure switch and returns back to the power plug.
if this pressure switch is not working, you have to install another kind of switch of on and off the compressor.
Sep 13, 2012 | Porter Cable C2002 150 Psi 6 Gal...
Replacing the Contactor on my Rudd AC model uaka-037jaz. I got a Dayton 2utl4 contator for a replacement. I need to know which wires connect to what location. I hooked it up with the 2 thermostat wires...
On this unit wiring is very basic, line in wires to the two lugs on the bottom, common as refered to is always black wire which goes to the compressor and the fan motor, red to adjacent lug of the contactor which then one goes to the capacitor and one to the compressor and one to the outdoor fan motor. One wire usually yellow from capacitor to start winding of compressor marked on the capacitor as herm, and a brown wire to the fan motor from the capacitor. The side connectors as you know go to the 24v control coil. The reason as to the fuse going out could be due to loose connections in the disconnect box or a short in the wiring at the compressor, fan motor or capacitor, and worst case a shorted compressor internally. Recommend having the system checked with the proper equipment to include an ohm meter with uf reading ability.
Aug 24, 2011 | Heating & Cooling
Don't know how to connect capacitor
Locate the Run terminal on the compressor ( marked R ) that wire goes to one side of the run capacitor usually has a mark ... the other wire will go to the common bar on the selector switch. On the other side of the capacitor goes the Start Terminal of the compressor No other wire goes with that just one wire from ( S ) on compressor to capacitor. Hope this keeps you cool!
Jul 18, 2011 | Heating & Cooling
I have replaced a compressor in a maytag fridge model MBB2256GES and i have a blue wire and a white wire i know they go to the compressor and ther are three pins on the compressor what goes where
The start component assembly goes to the three pins. You have to have this assembly. Always shipped with a new compressor.
The 2 wires go the start kit, after it's installed onto the compressor. Doesn't matter how you use the blue and white wires. Just connect them to the relay start kit, where the old ones were.
Sep 17, 2009 | Maytag MBB2256GES Bottom Freezer...
I have a Coalman Powermate 6.5 Hp 60 gal. compressor model C650C600VIB103. I want to know to connect the elect. cord correctly.
Does the unit have a starter or just a pressure switch , if just a pressure switch it should be marked with line and motor , the wires on the motor should go to the motor terminal and the line terminals are the power supply , if the unit is 110 volts make sure you put the wires on by color , the white wire goes to the motors white wire and the black to the motors black wire , if this is 220 volts it does not matter which wire connects just put the two black wires on the line terminals. One wire per terminals please.
Jul 17, 2009 | Coleman Powermate 60 Gallon Air Compressor
Need wiring diagram for Ruud Model UPCA-048jas
The wiring on these is pretty straight forward
Basically a contactor, either DPST or DPDT, depending. Input power connects here.
Compressor C terminal connects to one side. R terminal connects to the other. 1 terminal of the run capacitor connects to the terminal with the R terminal of compressor. The other side of run capacitor hooks to S terminal of compressor. One wire of condensor fan hooks with compressor R terminal, the other condensor fan lead hooks with compressor C terminal.
Only things missing from all this is a hard start kit and crankcase heater. Let me know if you want to know how to hook those up.
Jan 29, 2009 | Ruud UAMB Air Conditioner
I NED TO CONECT 3-1 RELAY OVERLOAD CAPACITOR IN MI FRIDGE
first take all the relays and capacitor off of compressor , then attach black wire with terminal on "C" terminal post usually top terminal, white wire with terminal goes on "S" terminal post on compressor, red wire with terminal goes on "R" terminal post on compressor. then take the two black wires one connects to white neutral wire and the other connects to the black power wire if tis fridge has a condensor fan then you will also need to connect it two the two black wires also thanks hope this helps
Jan 23, 2009 | Kenmore 50522 / 50524 Side by Side...
Turbo Air TSR-49SD Stainless Steel Commercial Refrigerator Logo
80 people viewed this question
Top Turbo Air Refrigerators Experts
Dennis Boxerman
ray gallant
John Tripp
John Tripp
Are you a Turbo Air Refrigerator Expert? Answer questions, earn points and help others
