Question about HP LaserJet 1320 Printer
Hello,my hp laser jet 1320 does not work correctly,I work under an office network, some time it prints and some time does not print specially about pdf files or high size files, the alert is: fail to print. after restart it can print but only one page ,then the alert repeat.
  • yaldda_night Jul 19, 2009
    i re installed it but no change
  • IT Solution
    IT Solution May 11, 2010
    Re install the driver software
Is there a typical application you are using? I noticed that file size (especially in adobe) can be an issue. If you go to printer settings (start / settings / printers / right click on the 1320 and select properties) choose device settings and the very bottom item is printer memory. I would increase this to like 80mb.... hope this helps
Posted on Jul 20, 2009
I have an hp 1320 laser jet printer but it cant be recognized by all the computers in my office. i have tried to change both usb and parallel cables but nothing is happening . what could be the problem?...
Have you connected it via Ethernet and installed the software on your office's server? If not then you will have to set it up as a USB or parallel on one pc and then all the other computers on the network will have to print to the IP address on the network of the PC it is connected to and then set up each machine to access that printer.
Aug 24, 2011 | HP LaserJet 1320 Printer
Problem: Not able to print mirror image in HP Laser Jet 1320 Printer. Please help. OS: Windows XP Printer: HP Laser Jet 1320 Software: Adobe Pagemaker 6.5
To reverse an image for iron-on transfers
1. On the File menu in your software application, click Print.
2. Make sure the product is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Click the Features tab.
5. In the Paper Type drop-down list, click More, and then select HP Iron-on Transfer
from the list.
6. If the selected size is not what you want, click an appropriate size in the Size list.
7. Click the Advanced tab.
8. In the Features area, select the Mirror Image checkbox.
9. Click OK, and then click Print or OK in the Print dialog box.
For support call Our Toll-Free 1 888 224 4280
Jan 20, 2011 | HP LaserJet 1320 Printer
I HAVE A HP LASER JET 1320 PRINTER . HOW CAN I GET IT TO PRINT A LITTLE DARKER.
first your printer connection reset,cover open to set paper correct setting,next manuvel move paper
thats it.
Oct 27, 2010 | HP LaserJet 1320 Printer
I have a 1320 printer that just prints blank pages
If ink is ok , then you may need to reinstall printer drivers.
Unplug printer USB.
Go to control panel>>Installed printers and delete existing printer installation.
Reinstall printer driver software using printer CD.
Mar 02, 2009 | HP Laser Jet 1320 Printer
My laser jet 1320 will not print.
hi,
that might be problem with yur printer data cable,
kindly replace it and check.
thanks Ravi
Dec 14, 2008 | HP LaserJet 1320 Printer
Re: HP 1320 won't take the tray designation for 2 and 3 Help
Hello classygirl,
I had this exact same problem and resolved it by downloading the HP LaserJet 1160/LaserJet 1320 North American and Western European Full Printing Solution which can be downloaded from support.hp.com.
Because the 1320 does not have a built-in interface, installing the basic drivers will not work. You must download and install the full 400+mb package.
Hope this helps!
Aug 28, 2008 | HP Laser Jet 1320 Printer
Not working on window 2003 server as a network printer
I have had a similar issue with both laserjet 3005N and 1320N machines setup as network printers on a windows 2003 print server. Both machines install correctly and print test pages but once you push to much of a print job to it (in my case it was a 12mb pdf file) the printer stops printing and never prints again for some reason. After a quick reboot a test page will print but what gives?? Buffer issues? Not enough ram? None of this makes sense since the printer displays nothing and just stops printNo test pages or anything. I tried re-installing it and rebooting it. Nothing.
Jul 12, 2008 | HP LaserJet 1320 Printer
Printing fent text
have you try to replace the toner ?
could be that or your fuser or dust in the laser assembly.
Jan 16, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
370 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
