Question about Dual Electronics CECT P168 Cellular Phone
"not allowed to dial"on f003 phone
I cannot find a way to call out, per the manual , call set-up >>all calls restrict dial all calls, except emergency calls. I cannot find this option on my phone. I go to call center >call settings>ok>sim1 call settings or advance settings> 1 black list 2 ip dial 3 background sound 4 call time display 5 call time reminder. Is there another icon that i can use to get to the settin so i can undo "all calls restrict dial all calls?
It was working for a while until yesterday.
hi mate,just follow these instructions 1. make sure to have 2 sims in phone(do not use 3g sims) 2. make sure wlan is disabled 3. enter engineer mode (type in *#3646633# 4.scroll up not down to number 10 RF test tool 5.choose gsm touch ok verify ok touch power scan 6.select band dcs 1800 press ok phone will go to test looking for DES(frequencies) wait until phone crashes or seems inactive(can take 3 to 15 min) press the end button (red one) phones with one middle button use that one phone will go off turn on phone and it will be reset to flight mode....(you can try to make call to verify,phone wil say cannot make call,not, not allowed to dial like before) go to settings and network setup,sim1 network setup,prefered mode and select gsm prefered...(phone will now change mode unlike before saying unfinnished) try the phone to make a call (should be no prob now) not finnished though .... go into settings again select restore factory settings (password 1122) wait for phone to restart...now its all done .....now you can change your tones and turn wlan on etc do not for any reason select wlan only or gsm only again...
Posted on Sep 19, 2009
This is for another similar clone marked with the "vaio" name but it might be useful to someone out there. I found that by following solution one above (thanks Mrfixit) to step 6 as below and then following the second part of what I found at http://chinamobiles.org/archive/index.php/t-16088.html worked for me. I reproduce the steps below:
BUT THEN
Connect your mobile via USB cable to a PC, DO NOT CONFIRM any connection mode at your mobile, just and ONLY connect the cable!!!
11. Press the Menu button (second from the left, the one with the seven small dots on it) until you are at the main menu with the 12 icons on the display.
12. Go to "Settings" --> "Network Setup" --> "SIM1 network setup"
13. Go to "Preferred mode" and choose "GSM preferred" or "GSM only"
14. The mobile will switch to your selection, but the message that it will stays on display. Do not press anything else, just wait for about 10 - 15 seconds.
15. Disconnect the USB cable from the phone, it will show you that it has switched to your selection.
16. Get back to main menu, switch off and restart the mobile --> DONE
Posted on Oct 20, 2009
  • dr_rolp Mar 15, 2011
    perfectly documented, many many thanks, i will add your post to my blog
    Problem Solver:
  • 4 Answers
Jdrimorin - did you ever get it fixed.
this is actually a known bug - check your Network Setup > SIM1 network setup > Preferred mode settings. You may be stuck in "WLAN only". When you select any other option the phone states "mode switching" and then "unfinished".
For some reason this prevents outgoing calls "not allowed to dial" and I have seen some mention of a software fix - not sure how to get it though.
Posted on Aug 14, 2009
Here is the step by step solution I used to remove the "not allowed to dial" message and allow me to dial out again.
  1. turn off the phone
  2. place 2 sims on the phone
  3. restart the phone
  4. keep the WLAN disabled
  5. enter the engineering mode * # 82043036 #
  6. select the option RF Test Tool (on my phone it's option 13)
  7. Select GSM, to accept him
  8. go to Power scan
  9. go to Band Select and select OK DCS1800
  10. another screen will appear (model F003) look at each of the options until you find one that will have your phone appear unresponsive (this locked)
  11. pressing the main button (the box) will take you to the home screen
  12. go to the setup menu
  13. go to network settings menu SIM1
  14. this is a preferred mode
  15. select one of the preferred modes GSM or WILAN
  16. restart the phone and you should be ready to make calls
Posted on Mar 07, 2011
How do i have to enter engineer mode?
Posted on Oct 04, 2009
  • 520 Answers
The big problem is the not allowed to dial issue which I have found the solution but if you can make emergency calls you are not stuck in wlan only mode.wlan mode wont allow any number to be dialed whatsoever.
not allowed to dial fix
tat24me@yahoo.co.uk
Posted on Sep 01, 2009
  • tat4u
    tat4u Sep 01, 2009
    if youre not stuck in wlan mode then you should be able to solve the call barring prob by reset to factory mode in settings..
    If you have the not allowed to dial prob email me for the solution
    no charges
    tat24me@yahoo.co.uk
  • tat4u
    tat4u Sep 04, 2009
    the not allowed to dial problem is not a software error or bug it is a programming issue....I have the solution to fix it and enable you to make calls ..
    if you want the solution just email me at tat24me@yahoo.co.uk
  • 520 Answers
Go to screen with call centre icon and touch it...touch call settings...touch sim1 settings....touch call barring...
touch cancel all...enter password(1122 default)
if any barring set they will be cancelled if none set(barring not activated)it will say not done
  • aviacoke Jul 13, 2011
    how do i turn off wifi c5000 wifi mobile
Check this out:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140343360848&ssPageName=STRK:MESELX:IT
I have the same problem with my phone. But when I try to open the engineering mode *#82043036# nothing happens. When I push the dial button this massage appeares NOT ALLOWED TO DIAL.
Can you help me ??
Posted on Mar 29, 2013
Not allowed to dial ------ zoho v 709
Posted on Aug 09, 2009
    President:
  • Dual Master
  • 688 Answers
It sounds like your phone is locked to a provider.
this phone should come unlocked but if your change the software or let the battery die all the way it may have locked itself again.
try http://forum.gsmhosting.com if may be easier to find an unlock solution
Posted on Jul 19, 2009
Hoe I do disable outgoing call FDN restricted
Fixed Dial Number (FDN), allows you to restrict outgoing calls to a limited set of phone numbers on your Samsung Galaxy Note 2.
How to enable FDN on Samsung Galaxy Note 2
  • From the Home screen, tap Phone icon.
  • Press Menu key and then tap Call settings > Additional settings > Fixed Dialing Numbers.
  • Tap Disable FDN.
  • At the prompt, enter your PIN2 code and tap OK.
Mar 10, 2015 | Samsung Galaxy Note II GT-N7100 16GB Gray-...
I need to block certain extensions from being able to dial long distance
Best way to do that is to sit down with the manual and look at programs 400-408. At a minimum, if you restrict 1 and 0 in a table and assign it to your extensons in 405, those phones can't dial long distance. That's fairly worthless in today's calling climate when some carriers let you dial just 10 digits or you have to dial 1 for any local call outside your area code. 404 lets you build 8 tables of 10 number sequences each for restriction and 407 lets you build 8 tables of 10 number sequences for allow. For example You could put 1 HOLD HOLD HOLD (hold is the wildcard) in one table and entry of 404 with traditional dialing and that would restrict all 1+ long distance. Then, in 407 5 of your entries in one table would be 1800, 1888, 1877, 1866 and 1855 to allow toll free calling. These tables get assigned to extensions in programs 405 and 408. A simple restriction (ie local calls only, internal calls only) get assigned in 401. There are some other tricks and, above all, remember that you have to keep 911 availabe for access and allowing 0 is never a good idea because 0 alone will get the operator and that defeats the purpose of toll restriction.
Other tricks involve custom CLASS codes. You need to account for the clever worker who dial *67. That gives them second dial tone and they can dial the world. It would be easy if you could block first digit *, but you ought to allow *57 for nuisance call trace. If you have the above where long distance is dialed with only 10 digits, then you can always start with HOLD HOLD HOLD in a table and allow 911 and the local area code in an allow table. The table digits can be up to 12 so you may have to go to 6 digit screening in allow tables for local exchanges. In my area, we have 10 digit dialing and 419352 419353 419354 (among others) along with 567213 are local calls. If I were programming a customer 6 miles to the North, there would be extensive programming in both area codes.
Outside of that, it's just a function of analyzing your local calls, area codes, how a call is dialed, and building your tables. We do this with billing by the hour :-)
Carl
Apr 07, 2011 | Lucent PARTNER18 Corded Phone
Can we make it so the phone can receive calls but not make out going calls?
You can, but you need access to Installer level programming. I'm not going to give you detailed instructions here, because any fool can do the reverse and UNrestrict a phone with the same instructions, but system program 500 and 501 sets day and night restrictions on a phone. Setting the COS to 7 lets the phone dial 0, intercom, and, by programming, System speed dial numbers.
COS 8 allows Operator only (internal operator).
By building tables, you can actually program different restrictions and exceptions for COS 2-6. There's a fairly comprehensive discussion in the Panasonic Features Manual of your TD 816/1232 manual.
Carl
Feb 18, 2011 | Panasonic KX-T7431 Corded Phone
How do i block local calls, mobile, as well as int'l calls from kxt7730, im using kxt824.i have 8 digtal extensions. i need to open from 101ext to allow local and mobile. thanks
When you get out the Features Manual, look and review Toll Restriction (TRS). You set the Class of Service on a phone to something other than 1 and then build tables 2-5 to restrict or allow certain digits. The Programming Manual (notably 302-305 and 306 being the exceptions) contains the data, the FM the instructions.
Carl
Sep 14, 2010 | Panasonic KX-T7730 Corded Phone
I have a starplus sp7050-02 I am having trouble with forwarding calls. my phone company started a new program last week. I used to dial 72# and the phone would automatically transfer to the answering...
That's an easy one....sort of. If you have a DHS manual, you'll have to go into your restriction tables and allow *72 on whatever phone you are using, or better yet, put it into speed dialing where it is not subject to dialing restrictions. The reason for restricting * in the first place is because you can use other telco features like *82 and dial the world. It keeps your users from finding ways around toll restrictions. When * is required, you have to specifically allow *72 and *73.
Carl
Aug 26, 2010 | Vodavi Starplus SP7314-08 Corded Phone
How to block "0" for international calling and mobile calling in our office phone panasonic model no kx-t7730x
As was pointed out to me, you could take a screwdriver and pry the 0 key off the tone pads :-)
Panasonic systems restrict calls by tables called Toll Restriction (TRS). It's a complete section in the installation and programming manual. It involves setting tables, usually in the 302-306 area, then picking a class of service for the phone that acts on the numbers dialed.
In the simplest systems, the TA series, you have 20 restrictions per class 2-5 and one 80 entry exception table. It's a little tricky to set up in that a COS-2 extension has all the restrictions in COS-2 tables, but a COS-5 extension has all the restrictions in COS-2,3,4, and 5 :-)
Your Pana installer can do this fairly quickly, but if you plan on doing it yourself, please read the TRS examples carefully.
Carl
Aug 20, 2010 | Panasonic KX-T7730 Corded Phone
Error message "Number FDN restricted"
I can receive the call from outsider but wont be able to make call to outsider. When I trying to dial out to somebody it says "number FDN restricted" Please help.
Jun 14, 2010 | Samsung SGH-t219 Cellular Phone
CECT KA08-how to set up speed dial?
Follow the following:
>Call Center at the bottom
>General call settings
>03 Speed dial
>Check that "enable speed dial" is on
Then
>02 Set number
>You will see a list of "empty"
>Touch on the one you want to assign a number
>Edit
>this takes you to your phone book
>Choose a name from your list and save it to your speed dial.
>To call the number from your speed dial list, click on the "Phone dial" icon, and hold the number down. For example, is the number 2 is home, hold 2 down until you see it dial and there you have it.
Hopes this helps
Jul 29, 2009 | Dual Electronics CECT P168 Cellular Phone
Mi F003 show the error NOT ALLOWED TO DIAL tis is a video of the error: http://www.youtube.com/watch?v=bhJj21J6z_M Thank´s
Guys I had the same problem with the k599 Sciphone and none of the solutions found on the internet helped me. New chinese models tend to restart after testing is over and this results in turning the wifi application on. So I spent many hours on thinking how to bypass this function and this morning I woke up with an idea that really worked!! The steps are quite similar with the ones followed to debug older models:
put 2 chips on cell
Disable WLAN.
1-enter in factory mode *#3646633#
2-go to RF Test Tool
3-choose GSM, confirm OK!
4-go to Power scan
5-Select Band DCS1800 click OK
6-the cell frozen
7-wait for 3 minutes testing
8-while testing connect to a pc using the USB cable (do NOT select ANY of the options appearing on the cell screen)
9-Click the CENTER button of the cell until you go back to principal menu
10-go to settings/network settings and choose GSM Preferred or any other option (except WLAN only!!)
In this way the cell does not reboot, and the wifi application stays off, so the option can now be changed...
Hope this helps!
Greetings from Greece!
email me to akiss_bd@hotmail.com if any questions
Jun 30, 2009 | Dual Electronics CECT P168 Cellular Phone
Restrict call in model k750i of sony ericcson
Hi there.. block the incoming call barring feature. we can restrict incoming calls and add prefered people who are allowed to call. this feature is present on most sony ericsson phones.
to enable it go to settings->call settings->manage calls->accept calls. add the allowed people phone no.s in the list and turn on the "only from list" you will not get call from people except one in the list.
ok
peace!
Feb 17, 2008 | Sony Ericsson K750i Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
8,063 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
