I have a Coleman Evcon Heat Pump Model DRH50481CB runs for a couple of minutes then shuts down.The pressure readings are good when it shuts down.If I wait for 15-30 minutes it will run and do the same thing ?
  • 614 Answers
Sometimes there is float switch inside. It open when you have stopped up drain. It could be tripping and slowly draining and bringing the unit back on. Check this first. Evcon did not put low pressure controls on there units. Could be bad capacitor also but check float switch first. Russ
Posted on Jul 19, 2009
Coleman evcon ignites but hardly any heat at vents blower motor workin constantent running
Dirty evaporator coil, dirty air filter, weak blower motor windings, weak blower motor capacitor, wrong blower speed, leaking or broken ductwork, uninsulated ductwork, gas valve pressure needs adjusting(low fire)? Might be any or all of the above.
Nov 02, 2017 | Coleman Heating & Cooling
WHAT SHOULD THE heat anticipator BE SET AT ON A MODEL COAT066BDA COLEMAN EVCON FURNACE
The typical starting point for heat anticipation is .4 amp. If you do not have a clamp-on ammeter, adjust it to .45 and observe operation for a few days. If not quite right and still short cycling slip it to .5. Then keep doing this until you are satisfied cycle time is correct.
If you have an amprobe or can borrow one, remove the stat and take a single loooooong thermostat wire. Attach it to the R or Rh and wrap it around the clamp on ammeter ten times then attach the other end to the W terminal. The furnace will initiate the heat cycle at that point. Observe the amp reading on the amprobe when full heat is on, DIVIDE that reading by ten (for the wraps of wire) and adjust the heat anticipator to THAT setting.
Feb 05, 2015 | Coleman Heating & Cooling
Coleman Evcon model DLAS075ADC, glow plug lights, fire starts, then the blower comes on,..after ten minutes the whole system shuts down and will not re light, what is causing this?
Check to see if the pressure switch is sticking...it wont restart the furnace if it is already pulled in before the inducer motor is called to kick on.
Dec 17, 2013 | Heating & Cooling
Bryant furnace model FX4C, FY4A with heat pump and a/c will not switch from a/c to heat pump. Only have heat with emergency heat on.
WELL this could be a couple of problems the reversing valve could be stuck either from not enough pressure which would be a leal and low on freon or the unit is off on low pressure switch/high pressure switch from either being low on freon or something restricting it and caused unit to shut down, ive been a servicer for many years and if it gets below 30 degrees outside i would recommend running the e-heat anyway it does cost more money minute for minute. but you will find it will heat alot faster in those colder nights than the heat pump therefore cost is about the same.
as far as not switching over could be low on freon or a stuck reversing valve... is the outside even running in cool mode if not the you may have a tripped pressure switch...good luck
Jan 04, 2011 | Bryant Heating & Cooling
Coleman Evcon BGU12520A won't ignite
check the ignitors condition is it cracked broken burnt out etc , ifn so then it will need replacing , or check the pressure switch is working try jumping it out and see if the ignition glows ,
Apr 09, 2010 | Heating & Cooling
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Coleman Evcon model DGATO70BDC Starts to run then stops?
What you have is an ignition problem and your unit is shutting down on safety.
May 01, 2008 | Heating & Cooling
Heating & Cooling Logo
271 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
