Question about GE Refrigerators
GE WATER DISPENSER RUNS SLOW AND GIVE WARM WATER
Changed filter on the outside ,but not the one built in. Water started running slow about 2 months ago. Now after changing outside filter it runs warm and still runs slow .
  • GE Master
  • 1,606 Answers
With the refrig , you should have gotten a small bypass piece which fits in place of the inside filter . Install this to see if the filter is good or not . Water faster , replace filter , still slow , possible water valve problem . Also use a connector usually a 1/4 x 1/4 compression fitting , to bypass the outside filter for test purposes only .
Posted on Jul 19, 2009
Water dispenser runs very slowly. it doesn't seem to run slow to the machine, just through it. Is there an easy way to check the line? also, I read that there was a water reservoir somewhere... should I...
The filter may be the cause of the slow dispenser. They don't last forever.The inlet screen to the water solenoids where the water line connects to the fridge may be partially blocked. Heat from the night lite bulb can deform the plastic tube at the dispenser outlet and restrict the flow. Check all of the above and you'll find it.
Oct 31, 2017 | GE Monogram ZFSB26DRSS Stainless...
Water flow of filter too slow
When was the last time you changed the water filter? If the filter is clogged from long usage it will slow down the water flow. Filters should be changed 6-12 months.
Jul 11, 2010 | LG LFX25971ST Bottom Freezer French Door...
If it's not the filter, then the water valve is most likely defective
Oct 30, 2017 | GE Monogram ZFSB26DRSS Stainless...
GE GSL25IGRE BS slow water dispenser
Sounds like your water valve may need changing, and has filled up with sediment, slowing the water flow.
Mar 29, 2010 | GE Profile Arctica Stainless Steel Top...
GE side by side refrigerator water dispenser slow starts.
Well, the age doesnt help it, but have you ever changed the filter and had it all cleaned, if not all must be cleaned and filter changed, that should do it
Feb 09, 2010 | GE GSH25JFR Side by Side Refrigerator
Low water flow after changing the water filter in a gf profile re
Just a suggestion, you could try installing a filter on the water supply line to the fridge. A nice one should dramatically lessen the frequency of replacing the one in the fridge. As for your the pressure being low, look for a kink or pinch in the water supply line.
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Slow running water dispenser
the inlet water valve should be replaced but first go to where the water is connected to the pipe and close than open the valve all the way
Aug 09, 2009 | Refrigerators
Filtered water
the water line that run through the freezer door is frozen. its been a common problem on the GE built refrigerators. (that who built yours for sears) dis connect the water hose hehind the kick plate below the freezer door. use a hair dryer to warm up the inside and outside of the door around the dispenser area to defrost the line. it will take anywhere from 15 to 30 min to get in completly defrosted but it will once it is defrosted
Nov 24, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
660 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
