#!) Owners Manual: Did not get one from Office Depot. Can not fully use my new TV #2) I have a HD-Analog Air Antenna, but TV does shows 0 Analog Channels during Auto Search although I know there are 6 in my area. They come in on my other TVs
  • 334 Answers
If you are in the USA then not sure if you are awarre or not but there are no longer any anlog signals broadcasted. I would need to know the manufacturer and model number of your device in order to help you at all
Posted on Jul 19, 2009
No picture or sound
You need a antenna HD for air signals. I hope this helps. leave feedback and thank you
Jul 11, 2016 | Televison & Video
How do I change my service from analog to H D?
Most LCD tv's built in the last 4 years are HD compatible. Most cheaper brands tv's are 720 HD and some are full HD 1080 a little more money. Since their is no more analog broadcast as June 2009 all tv's manufactured around 2006 started incorperating the digital tuner (DTV) along with the analog so that the tv would still receive analog broadcast while the digital transistion was ongoing. All tv's with a Cathode Ray Tube (glass picture tube) are not HD compatible. First you will have 1 or 2 ports on the tv ethier on the side panel or rear panel of the set. They a marked HDMI 1 HDMI 2 or HDMI A HDMI B. If you have these ports your set is Hd Compatible. You may also need to upgrade your cable or satelllite equipment and subscribe to a HD package to be able to get HD service. You will need a HDMI cable to connect your cable or satellite receiver to the HDMI port on you tv. Call your local cable or satellite provider for options to upgrade to HD. Most over the air broadcast stations depending on your area transmit some stations in HD free of charge. A good quality outdoor antenna works best to give you stable signal. You may need to change the settings of the tv as some sets default to the 480i this is the standard digital signal.
Sep 10, 2014 | Televison & Video
Www dynexproducts com
go to MANUALSLIB.COM. ENTER THE UNIT # AND the manual will show up with the table of contents. Look for[ how to install antenna], the correct way is demonstrated with the jpgs. lol.
May 10, 2014 | Dynex Televison & Video
Mintek DTV-260
The Mintek DTV-260 only has a NTSC (analog) tuner. You will need to connect your RCA antenna to a digital to analog converter box to watch TV over the air. Then connect the output of the converter box to your TV.
The common converter boxes are limited to SD output. You might be able to find an HD converter box online. (With the standard converter box, the available outputs are coaxial and composite video.) The DTV-260 has a composite video port; alternatively set the TV to channel 3 or 4 and use the coaxial (RF) input on the TV.
There may be a low-power station that still broadcasts in analog. However these are rare. You will need to switch from CATV to OTA (Air) to check for one of these stations. Analog Cable has different parameters than scanning for over the air signals.
I hope this helps.
Mar 04, 2014 | Mintek Televison & Video
I want to know if my Zeineth TV #B32A24Z is analog or digital
This is a Analog set. If you use an Indoor antenna or Outside antenna you will need a converter box. If you are on cable you won't need a box.
May 01, 2009 | Televison & Video
New TV doesn't register being HD ready during test TV stations do
Try going into the setup menu and make sure it is set to antenna then do a channel program. You don't need to wait for a test there are plenty of channels already there. Both digital and analog channels are still available so you will still a message that you are not receiving digital if you are putting it on an analog channel. The channel number has to have a dot(.) in it like 8.1, 24.1 If there is no dot you are on an analog channel
Mar 13, 2009 | Westinghouse Electric W1603 15.6 in. LCD...
No DTV on my 2006 Polaroid FLM-2632 model 2700?????
Try going into your menu and putting the input to Antenna, then reprogram, let me know!
Feb 18, 2009 | Polaroid FLM-2632 Television
Using an over the air antenna I get all channels but one.
I experience the same thing on a day to day basis. The key, is location of the antenna. Depending on where your antenna is located, determines if u can recieve local CBS analog v. digitial. I actually tried sticking aluminum foil to my old rabbit ear antenna legs. to my surprise, I even picked up digital channel I never knew existed. Besides, when the signal transmit in Digital, u are already prepared. Your local CBS afilliate station will be accesable on maybe 2 or 3 channels. example:
Channel 10 analog
Channel 10-1, 10-2, 10-3 digital HD will all broadcast the same programming.
hope this helps u out.
Dec 06, 2008 | Dell W4200 42 in. HD-Ready Plasma...
Do I have a ATSC tuner in my 2002 Quasar 27" TV?
NTSC is the (analog) standard passing into history in Feb. '09 and ATSC is the new digital standard being used afterward for over-the-air (reception by antenna) broadcasts. This changeover affects only the broadcast channels and if you have cable or satellite reception the changeover will happen whenever they find they can't charge their captive audience such a high premium for HD.
I found no evidence that your set is ATSC ready so if you are receiving your signal by antenna, you need to scurry about and buy a converter for your set. Make sure the one you buy is on the list of 'approved' models to which you can apply the $40 coupon(s).
Coupon & info site
Oct 05, 2008 | Quasar SP-2725 27" TV
RCA P52939 - Can it receive HD-Only signal? Is it Analog-Only?
The P52939 RCA is a analog Standard TV you will need the Digital converter to receive digital signals
Feb 10, 2008 | RCA P52939 52" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
