Question about HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard P/N: 417035-0...
Showing a red line at the center on the monitor of my hp note book (dv2713tu). I think my video card or lcd panel is faulty.What might be the cause? If my video card/ lcd panel is to be replaced, Please help me knowing the price details of video card/lcd panel and proceedures to replace it.
  • 374 Answers
FIRST OF ALL TRY CONNECTING YOUR NOTEBOOK TO ANOTHER MONITOR...THIS WILL TELL IF THE LCD SCREEN IS FAULTY OR YOUR VIDEO CARD. IF YOUR LCD SCREEN IS FAULTY AND YOU WANT TO DO IT YOURSELF http://www.insidemylaptop.com/remove-lcd-screen-inverter-board-hp-pavilion-dv9000-laptop/all-comments/ A VERY USEFUL SITE.SCREEN WOULD COME IN BETWEEN $150-200 YOU CAN CHECK AT EBAY FOR THE APPROX. PRICE,YOU CAN EVEN CALL THE HP COMPANY AND ASK FOR THE REVISED RATES THAT WILL GIVE YOU AN IDEA. IT IS NOT THAT EASY WITH THE VIDEO CARD BECAUSE IT'S USUALLY ATTACHED TO THE MOTHERBOARD AND CONSIDER THAT YOU HAVE TO SPEND MORE BUCKS THAN THE SCREEN FOR A GOOD VIDEO CARD. I WOULD STRONGLY RECOMMEND TO TAKE IT TO AN AUTHORIZED SERVICE CENTER.
Posted on Jul 19, 2009
I have red vertical stripes, then white dots, then when windows loads, I have wavy red lines. Using Nvidia Geforce 9800 GT with Pavilion Elite m9350f. Is this my video card problem?
Okay you proved it is the monitor, but first sub the video cord from the computer to the monitor if possible, if okay! at this point you are looking at a LCD panel display problem, cheaper to replace than go through expensive repairs.
Mar 19, 2012 | HP w2207 Monitor
On my screen I keep seeing red vertical stripes. How do I get rid of this?
You can try to hook up an external monitor. If the vertical linea are visible on the external display, try to update your video card driver. If it is not showing in the external monitor, You are having an LCD problem.
If you don't have any external monitor, go to BIOS setup and check if the lines are visible, if yes, you're having an LCD/screen problem. You need to replace either the LCD cable, LCD inverter or LCD itself.
Hope this helps.
Jul 17, 2011 | HP Pavilion dv4-1020us Notebook PC
My Hp A6252D monitor keep turning to sleep by showing the message ' monitor is going to sleep' before it was turned off, but processor was still running. Sometimes, it hang and i hear noise from CPU. May i...
in power set up in control panel,there are setting for the computer and monitor,the setting is { shut down after 5mins,10 mins or never click never.and it should stay on
Jul 07, 2010 | HP W19b LCD Monitor
I have a fine horizontal line running 2/3rd's of my hp mini note book.should i be concerned?
This could be a hardware issue with the LCD screen of display card. To confirm the same, connect an external monitor and check if the same line appears on external monitor. If external mitor works fine, then its a LCD defect. If you have same issue on both LCD and External monitor, then it could be due to display card. In either cases you may need to take to service center.
May 22, 2010 | HP Mini 1000 Netbook
One yellow line on sreen vertically
Please try on another source (Another Computer or Note book). I suspect the problem with LCD panel of the monitor. Please take it to service center the will change the panel for you.
Dec 28, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Red line top to bottom in center of display ?
you lcd screen went bad-only way to fix it is to get a new lcd
Oct 22, 2009 | Compaq Armada M700 Notebook
Line of Laptop Displap
You could have a faulty LCD screen or a faulty video cable/connector.
Try reseating the video cable/connector that connects to the motherboard. If this doesn't work a replacement LCD screen may be required.
Check LCD Parts for parts and repair service, Use this link.
www.lcdparts.net
Jun 20, 2009 | HP Computers & Internet
Note book
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 03, 2009 | HP Pavilion dv6000z Notebook
Lenovo 3ooo c100 notebook
That is either :
Faulty LCD ribbon cable or connector slipping off.
Faulty LCD screen.
Faulty video adapter on laptop motherboard.
To find out you connect laptop to an external monitor.
If the problem persists on external monitor, then you have a faulty video chipset on motherboard.
If the picture is good on external monitor, then problem concerns LCD panel , or LCD cable on laptop.
Apr 06, 2009 | Lenovo 3000 C100 Notebook
Red Vertical lines on 15" Acer LCD Monitor
I think this is most likely a monitor problem. Can you try a different monitor of computer to the monitor? That would help pinpoint the problem. Is it under warranty?
Sep 17, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard  P/N: 417035-0... Logo
165 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
