You didn't mention the OS that you are using,I'm considering XP so here's the solution:
Click Start, and then click Run.
In the Open box, type regedit, and then click OK.
In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
On the Edit menu, click Delete.
When you are prompted to confirm the deletion, click Yes.
In the right pane, click LowerFilters.
Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
Exit Registry Editor.
Restart the computer.These steps will surely fix your problem.If you still face any problem then just let me know.
data burner said no cd in man dog multimedia dominator 52x but thier is.i'm running nero 6 oem...
(More)
DATA BURNER SAID NO CD IN MAN DOG MULTIMEDIA DOMINATOR 52X BUT THIER IS.I'M RUNNING NERO 6 OEM SUITE.CAN'T FINE UPDADE DRIVER.
hello sir/madom my name is palamkuttalmathai i did not use any cdearth software but november28...
(More)
hello sir/madom my name is palamkuttalmathai i did not use any cdearth software but november28 cdearth took 38 pound from my mastercard do you can helpme that i can get that money back to my account
I've had this drive for awhile. But it is a good piece or hardware and I like it. It meets my needs...
(More)
I've had this drive for awhile. But it is a good piece or hardware and I like it. It meets my needs and works fine. Until the last update. Now, it is not coming up at all on my computer, and it will not read cd's. But, the light is on and the door opens? I opened my computer up and installed a new ribbon because I thought maybe the old was messed up in some way and it did nothing? Any idea what is wrong with it?
