Question about NEC MultiSync MT1045 Multimedia Projector
NEC MT1055 projector is having trouble finding component signal from my Sony dvd/hdd recorder/player, I have tried switching to component manually and the projector blue screens put it into auto and it displays picture with green hue (goes into RGB mode)does the same with my high def set box,and media player, but plays fine on component signal from cheap dvd player.Think something is wrong with projector
  • 2,237 Answers
Do a factory reset, take it off of auto select, manually select component, make sure the resolution is set up for hd.
Posted on Jul 22, 2009
Connect sony dvd to samsung tv
There are five ways to get the video and audio signals from the DVD player: HDMI, Coaxial, Audio/Video, S-video and Component video, which way did you use?
Jun 07, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
URGENT: How can I connect my tv to my NEC VT695 projector?
Do you want to duplicate the image going from the source to the projector on your TV? If so, then if your TV has a VGA port, just use the monitor Out on the projector. If your TV doesn't have a VGA port, you'll need an appropriate converter. (Avoid a VGA to component video or VGA to composite cable.) If you add a comment with more information on the inputs for the TV (or the model of the TV), then I will try to point you to the correct converter.
If you want to get your TV signal to the projector, you would need a set-top box (cable, satellite, digital tuner) as the source. Most TVs do not have a video output. You can connect a computer or DVD player to the projector.
The manual and quick guide for the VT695 are available from NEC here: http://www.nec-display.com/dl/en/pj_manual/vt695_491.html . The direct link to the English language version of the manual is http://www.support.nec-display.com/dl_service/data/manual/english/vt695_491_manual_e.pdf .
I hope this helps.
May 25, 2014 | Office Equipment & Supplies
Double vision my NEC MT1055 lcd projector has double vision on the menus - looks like the menu was burned in a half in to the left
looks like one of your lcd panels is ghosting. If remember correctly your going to be asked to replace the whole prism.
Aug 28, 2009 | NEC MultiSync MT1055 Multimedia Projector
Red coured picture Nec MT850
I don't think it's globe related, I'd be getting a quote on the electronics.
Mar 23, 2009 | NEC MT850, MT1050, MT1055, MT1056...
My NEC MT850 projects with a pink picture you can still see image but it is a very bright pink.
A pink image normally means a loss of green signal.If you are using Computer input you should try replacing your input cable to see if this is the problem. If it is pink with video also then the projector most likley has a internal problem.
Mar 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Dell 3300mp Projector No Signal found to Digital DVD
Guys, the projector doesn't do HDCP.  HDMI won't work.  You'll need to run over component or VGA.
Jul 09, 2008 | Dell 3300MP Multimedia Projector
NEC MT1055 Will not power up
Hi there
This sounds like a faulty Ballast ( lamp's power supply ) It will unfortunately need repair or replacement.
Mar 25, 2008 | NEC MT850, MT1050, MT1055, MT1056...
Can't record onto disc
press dub on your remote, it will open the menu choose your programme you want record then click on hdd to disc.
Mar 02, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
MT 1055
As the lamp ages it will get dimmer this is a 1500 hour lamp look in the menu under information and it will give you the lamp time.
Jan 06, 2008 | NEC MT850, MT1050, MT1055, MT1056...
REPACEMENT PARTS MANUAL
Hi there
You will have to be more specific on wich fan you want the part number of !
Nov 27, 2007 | NEC MT850, MT1050, MT1055, MT1056...
NEC MultiSync MT1045 Multimedia Projector Logo
253 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
