The Clock will not set (keeps flashing for Auto) and this seems to prevent oven from turning on. Cannot turn overn on. Tried everything in the manual to fix clock - no avail.
Depending on the make of oven, you have to press the buttons in a certain sequence if it is a digital one, try pressing the buttons in sequence, sometimes you have to press 2 together, and a third one at the same time,if it is a anologue timer, then make sure you can see the symbol of a hand in the display.
If you cannot get the timer of auto, then it is probably faulty.
Please rate my solution.
Thanks.
I want to buy a compact, simple microwave oven for warming up food, with a tray that turns. I prefer...
(More)
I want to buy a compact, simple microwave oven for warming up food, with a tray that turns. I prefer the mechanical kind, because it's simpler, but I can handle a digital model. I've seen an AKAI model mw-jn0717mp2 which warms up the food quickly. It seems to be an older model. What is a newer model of AKAI? Or any other brand that has enough wattage to warm up the food quickly and evenly?
We have the Perfect clean. I burt-on mess will not come up. We are not supposed to use anything...
(More)
We have the Perfect clean. I burt-on mess will not come up. We are not supposed to use anything but soap & water but I cannot get this to work. Any suggestions?
My Jenn Air oven won't self clean. I am setting it all as directed, but the lock and clean light do...
(More)
My Jenn Air oven won't self clean. I am setting it all as directed, but the lock and clean light do not come on. The oven is not heating up to clean, Help
