I need diagram of key board - Computers & Internet
  •  Brian
    Brian May 11, 2010
    The problem is with your question is what type of keyboard a standard or a more advanced ?
  • 51 Answers
Uh, why? There are several different keyboard layouts, but they should all be here:
http://en.wikipedia.org/wiki/Keyboard_layout
Posted on Jul 19, 2009
2000 au series 2 falcon fuse diagram
Try to get a new one and replace it. Going with a used component is never a good idea.
Good luck
Feb 20, 2014 | Cars & Trucks
This question is for Strech.Hey bro you have give me a whole lot of information I know you are a very smart guy especially when it comes to bikes.So I don't know if you caught my question about the...
As far as the terminal board (terminal block, terminal plate) , I assume you mean something like this:
http://img.jpcycles.com/zoom/382-054_A.jpg
You may or may not be using all of the connections (they come in different standard lengths, and might have more connections than you need).
Now, I can't remember which wiring diagram I sent, so I'm starting over with this:
http://shovelhead.us/specs/wire/1976_FL_FLH.gif
The lower diagram is actually an continuation (to the right) of the upper diagram.
On the upper diagram, item #1 (to the right of the headlight, with little spots inside of it numbered 1 - 11) is the FRONT TERMINAL BOARD.
On the lower diagram, items # 17 - 20 comprise the REAR TERMINAL BOARD.
These show how many wires go to each terminal connection (example, terminal #3 in FRONT TERMINAL BOARD shows 5 wires connecting to that one terminal, #s 9 & 11 are not used).
Now your wire colors MIGHT not be stock.
In which case a multimeter would help you chase the wiring:
http://www.harborfreight.com/7-function-multimeter-98025.html
Also, do you have a Fat Bob tank center dash ignition switch?
http://i.ebayimg.com/00/s/MTA5MVgxMjI2/$(KGrHqZHJDME63ZMWiUbBO3tGwQzH!~~60_35.JPG
Or a key switch mounted somewhere else?
http://demonscy.ipower.com/i_pics/ignition_17-124_1.jpg
If the dash switch, this might help:
http://img231.imageshack.us/img231/931/dashswitchwiringdiagram.png
If a key switch, three wires would be:
1 - hot lead coming INTO switch
2 - lead going to ignition, brake light, instrumentation (for running without lights)
3 - lead going to lights (headlight, taillight) for ignition AND lights.
Hopefully, this will start you off.
Fire back with any questions
Feb 08, 2014 | Motorcycles
Proform V650 Treadmill - Main motor does not turn
The board will most probably need replacing. Almost certain.
I repair this brand for the manufacturer.
Nov 06, 2013 | Proform Exercise & Fitness
Xt125x wiring diagram (2007-2010)
the ignition wires were cut?
Sep 26, 2013 | Yamaha Motorcycles
Safety key off
You need to reset the machine. see your instr. manual where located the reset b.
see the block diagram attached. the control board can NOT be reset.Test the key magnet for repulsion attraction or repulsion againt with your magenet refrigerator and replace if necessary.
God bless you
Dec 02, 2012 | Horizon GS950T Upper Control Board
Fix E3 error message
see your troubleshooting section in your instr. manual and enter the keys for clear the error.
However you must test:
a) test the input voltage motor, if there are the motor need repair.
b) test the output voltage board, for input voltage motor, if there are NOT the board is faulty., see the block diagram+ w.diagram
Nov 26, 2012 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
NOT WORKING DISPLAYS
Dear Sir:
Please do the following adjustment, see the diagram. adjust the reed switch.
2) Tight the flexible cord or ribbon cable from key panel.
3) Tight the connector from display board to main motor board or lower board.
4) See if you display board has +5VDC, is missing you have problem with the power supply.
5) Try to run your software calibration Inmediately for easy diagnose an troubleshooting. See the block diagram for Help you, that I did design.
sincerely. God bless you.
ernesto cuadra
managua,nicaragua. c.a
Feb 17, 2012 | Proform 285t Treadmill Drive Motor
I need change the ballast board on a HD-61FN97
well make sure that first u work in an antistatic area... you can achieve this by hooking the workbench or even urself up to the earth connection in a power socket( THAT IS IF U KNOW WHICH ONE THE EARTH IS) label every connector and cable to the board, draw a diagram if need to... use a NONSTATIC screwdriver to unscrew the board, it should slide out quite easily so this shouldnt be a problem, then take out old board, put in new one connect cables and connectors according to diagram u made, and shove it back in... so yeah not to hard, but antistatic is the key word
Mar 17, 2009 | JVC HD-61FN97 61" Television
Kt6v jumper settings
Some wiring can be confusing such as with the board we were using. As you can see the wires mainly connect from left to right but the hard drive LED and the Key Lock wires connect from top to bottom but still show where the (-) connection is. This is where you need to pay close attention to where things actually connect to the motherboard as many boards have similar configurations.
May 23, 2008 | Abit : KV7 Socket A KT600 Motherboard
Computers & Internet Logo
175 people viewed this question
David Payne
David Payne
