Question about Canon PIXMA MP150 All-In-One InkJet Printer
Pictures with horizontal lines
No matter how many new or refilled cartridges I use, my Pixma MP 150 prints horizontal lines on everything. Is there a solution?
Re: Pictures with horizontal lines
I'm assuming the horizontal lines you're gtting are dark lines, not white omission lines and you are not currently using a cartridge that is leaking (otherwise, this solution is not appropriate). I had the same problem, and after a good deal of frustrating experimentation, found that the problem was caused by the cartridges picking up and retaining ink left on the little absorption pads where they rest. Normally, the pads should accomplish just the opposite effect, but it seems that after a certain amount of use (especially if you've ever had a defective, leaky cartridge), the pads just get too full. As the cartridge moves horizontally across your paper, ink picked up from these pads literally drips on your print. Could appear as lines and also as small smudge dots at the lengthwise travel stops where the cartridge travel reverses.
I could see that it would be fairly easy to remove the pads and either clean or replace them if I were to disassemble the housing of the printer. If you wish to do a really thorough job and you feel confident in your reassembly ability, go for it. I chose a quicker approach and it's solved the problem for the past two months: Open the lid and wait for the cartridges to move over to the left (cartridge replacement position). Then, pull the plug on your printer (or they will move back to the right after a few minutes). Use a small flashlight to locate the two absorbent pads over on the right, where the cartridges normally rest. With paper towels or any other absorbent disposable, blot those pads over and over until you get little or no ink on your paper towel. While you're at it, give the whole area under the lid a decent but gentle cleaning using a soft cloth or swab. Might take a couple of prints to completely eliminate the lines, since you won't be able to clean the underside of the cartridge carrier assembly this way, but this should solve your problem
Posted on Nov 29, 2007
0 characters
3 Points
How do you change inks in a canon pixma mp 480 printer
Here is a screen shot taken from the Canon On-screen manual . Below is the link where you can download a copy of this manual which gives step-by-step instructions with pictures on how to replace an ink tank. :
To read the screenshot, simply zoom in by pressing ctrl++ at the same time until the you can read the font.
Apr 20, 2011 | Canon PIXMA MP470 All-in-One Printer
Photo Printing
How long ago did you replace the cartridges and how long ago did this problem develop?
Jul 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
Cannot send and receive fax after refilling PG-40
I own a Cartridge World ink refilling store and I think that the fax not printing is Canon's new approach to kick out refills from their all in one machines. We cannot reset the ink level indicators on these cartridges and if people can no longer print faxes if their ink says it's low, then they can never use refills if they want to use their fax machine. I think it is also a way for Canon to make more money on their ink sales by making consumers buy new ink before theirs runs out. As far as I know there is no way to fix this problem.
Feb 10, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon Pixma MP130 printing lines through pictures etc
I'd say it's probably the printer driver. Uninstal and reinstal it or update it. Printer drivers are a comon cause of printing faults.
Aug 16, 2009 | Canon PIXMA MP130 All-In-One InkJet...
PIXMA iP90, all the pictures come out really ink,
I've cleaned it every which way..but still all the pictures print out really realled faded with slight lines horizontally runnung across.
Mar 01, 2009 | Canon PIXMA iP90 Mobile Printer
Pixma MP 150 Error 5
just refilled my cartridges in hopes of saving some money and now I can't use them due to this E5 message. Please Help
Aug 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Refill canon pixma mp 150
Yes you could refill those types of cartridges, but i would not suggest it! Unoriginal ink will cause loss of quality and also if not sealed correctly it could spill allover the printer and will certainly cause damage.
Jul 29, 2008 | Canon PIXMA MP150 All-In-One InkJet...
No Idea how to refill
its not good to use refills.
can damage the printhead
Feb 01, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
144 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
