Question about Samsung SyncMaster 910MP 19" LCD Monitor
Dell computer screen black out
Dell computer screen just went black, just appear for a second when powers on
    Problem Solver:
  • 5 Answers
Try replacing a couple of the surface mount capacitors. Start with the 10uf's C604 and C507 this will usually bring them back to life.
Good Luck!
Posted on Mar 01, 2008
Screen went black but computer still
Sometime this will happen when the Dell machine is stuck in sleep mode. Press and hold to power button for about 10 seconds. You should see the fan spin just a little this tells you that sleep mode is off. now try starting the computer like normal.
Mar 17, 2014 | Microsoft Realsync Computers & Internet
Black screen blinking line in upper left corner
you just need to re-install the Operating System from recovery cd
Dec 19, 2012 | Dell Dimension 8250 PC Desktop
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
My home dell computer monitor has went black with a box on it. * The floating dialog box appeared on screen (against a black background) * The dialog box float around the screen without any visual...
The dialog box you are seeing means that the monitor is not receiving a signal from the computer.
check your cable going from the monitor to the computer. if the cable seems ok, hold the power button on your towerr until it turns off, then wait 5 seconds and push the computer power button again.
Dec 26, 2017 | Dell E152FP 15" Flat Panel LCD Monitor
When they went to do a system restore and when the computer went restart i have a black screen
Drain flee power and your PC should work !
Steps to drain flee power:
1. Unplug power cord,
2.Remove Battery.
3.Press and hold power button for 30 seconds.
4.Reconnect the battery and power cord and start your system
Dont forget to say Thanks !
Aug 09, 2010 | Dell XPS M1330 Notebook
I plugged it in and the screen came up for a second and then went black. I turned it off and turned it back on, the screen came up for a second then went black again. What could be wrong?
is the cpu running ,, with connection to monitor,, you can try restart,, and go to display properties,, screensaver,, there power button and change the settings,,,
Sep 27, 2009 | Dell E173FP 17" LCD Monitor
Monitor Screen goes black every few seconds!
Check the capacitors on your monitors circuit board. If they have opened up at the top, they are fried. Buy new ones, make sure nothing has leaked from the old ones, and replace them.
Sep 26, 2009 | Dell SE198WFP LCD Monitor
Video problem on my Dell Dimension 4600 PC, HELP ASAP.
the resolution set by default when you load your graphics driver is outside the range of your monitors capability.
try starting in safe mode then adjust your resolution to 640 by 480 then restart.
if this works, adjust upwards to 1024 by 768
then up again till the screen blanks.
when it does, dont panic, wait 20 seconds and the settings will restore - you then have the optimum settings for your monitor.
good luck
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Bottom third of screen went black
Vertical section problem
change all caps in vertical sec and replace vertical IC
Oct 10, 2008 | Dell UltraScan 1000TX 17 in.CRT...
Black Screen
No, this is typical problem for defective inverter. Mostly screen appears for some seconds and then turn to black. If you are technician, you can use this link :-).
Oct 01, 2007 | Dell 1703FPs 17" TFT LCD Flat Panel...
Samsung SyncMaster 910MP 19" LCD Monitor Logo
143 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
