SOURCE: vivitar vivicam 7388s lens won't go back into
Hi Dear,
This issue is not with the battery. This is due to the misalignment of the camera lens. This is a delicate hardware problem. Hence,i would suggest you to take it to some professional or your authorized service center and get it repaired there only. Trying to repair it on your own might make the situation worse and would cost a lot money.
If you need more information on this. Please do write to use.
Have a nice day.
SOURCE: Brand new Vivitar vivicam 8025 Camera. Once
Try flipping the battery over (where the metal connectors are pointing down).
SOURCE: EVERYTIME I TURN ON MY VIVITAR VIVICAM 8025 A BLUE SCREEN POP UP
you need to unplug the power lead and put in the memory card.
SOURCE: How long should the ViviCam X029 battery charge?
usually for a minimum of 10 hrs
please rate my help++++Thanks for using FIXYA
SOURCE: my camera flash is not
On the side of your camera is a switch. Looking at it you will either see mountains or a flower. For flash to work you must see the mountains. Then push and hold the up button that looks like a lightning bolt. The flash should work then.
It was a computer cord that is connected to a wall plug. Is this the problem?
It is a computer cord connect ed to a wall plug. Could this be the problem. Can I charge from a computer?
