Question about Discovery Channel Atm Bank
No instructions for atm discover toy
Can't get toy to open or operate. demo works. new batteries. pushed reset button. it accepts new name but we don't know how to set new pin number. won't accept old one. don't have original ATM card but any credit card seems to activate.
My son has a discovery kids safe....we lost passcode. Can it be reset? Numbers/letters on bottom of safe are: YLBSD-NI 2006 07 12330
The Discovery Kids Safe works slightly differently. When you press the reset button on the bottom of the safe, the code defaults to "1234". To set a new code, Press *, then your four-digit code, then * again.
Emergency Open: In case of malfunction, hold down "WIRE" button and push on the drawer.
Feb 15, 2011 | Discovery Kids Toys
I HAVE A DEH-P640 AND THE SCREEN IS IN DEMO MODE AND I WOULD LIKE TO KNOW HOW TO TURN IT OFF IT IS VERY ANNOYING DRIVING AT NIGHT THANKS RON
Feature demo
The feature demo automatically starts when
power to this product is switched off while the
ignition switch is set to ACC or ON. Pressing 6
numbered button during feature demo operation
cancels the feature demo mode. Pressing 6
numbered button again to start the feature
mode. remember that if the feature demo continues
operating when the car engine is
switched off, it may drain battery power.
Notes
• You cannot cancel a demo mode when the
front panel is open.
• The red lead (ACC) of this product should be
connected to a terminal coupled with ignition
switch on/off operations. If this is not done,
the vehicle battery may be drained.
Apr 27, 2009 | Car Audio & Video
I need the user guide for the time Tracker countdown timer
SET AUTO TIMER 1. Press and hold START and ENTER buttons at the same time for 3 seconds. 2. Press buttons until SET AUTO appears on the display. 3. Press ENTER. 4. Total Time: (Enter the total amount of time. It will automatically split between green, yellow and red lights). Use buttons to scroll through numbers and ENTER to accept. 5. Sound?: Do you want a sound effect at the start of the green light? 6. Yes/No: Use buttons to move cursor and ENTER to accept. 7. If yes, use buttons to scroll through sounds and ENTER to accept. 8. Repeat steps 7 and 8 for yellow and red sections. 9. Press MENU.
Feb 03, 2009 | Learning Resources Time Tracker Visual...
I have a skylink 318r keypad with receiver to open my overhead door but dont know code as sellers of the home didn't leave this with - how do you reprogram both transitter and receiver?
keypad is model 318K
receiver is model 318R
factory setting for keypad PIN is 0000 #
there is no master reset code
you must have the current code to reset the PIN
if you hit the correct code on the keypad followed by the # key - you will get three beeps.
to change the PIN: (current PIN needed)
enter current 4 digit PIN then *
enter new 4 digit PIN followed by *
reenter new 4 digit pin and *
if accepted - backlight will flash and will sound one long beep
takes 2 CR2032 button cells for keypad
you could sit in a chair one night and start at 0000# then 0001# etc until you get three beeps
then use above procedure to change to your desired code
good luck
Jan 29, 2009 | Locks & Locksmithing
Resetting Pin on Blue Hat ATM machine
Hi abbeybath,
We have the same atm/bank for our son. Here's the fix:
1 - push the reset button on the back of the ATM near the battery compartment.
2 - insert the ATM card and press the BALANCE button to change the user name (need to do this before getting to the pin)
3 - enter your childs name and push enter when complete. Cancel will delete an incorrect letter.
4- enter the default pin (1234) - this will bring up the DEPOSIT, WITHDRAWL, BALANCE screen.
5 - Press ENTER and it will show the current/default pin. Input the new pin number you desire and press ENTER again.
All set. Hope this helps!!
Jan 17, 2009 | Blue Microphones Blue Hat Little Shots...
Blue Hat Bank
Type in the code 1234 ENTER then enter your child's new pin.
Pax, Moncia
Jan 04, 2009 | Blue Microphones Blue Hat Little Shots...
Blue Hat Toy Company ATM - help! No setup instructions!
ok i hit the rest button on the back of the machine and it erased all my memory off of it so i had to reprogram it .If u put 1234 in as a pin # it will open then press balance and hit enter and u can change your pin # there .
Dec 25, 2008 | Blue Microphones Blue Hat Little Shots...
SUMMIT PRODUCTS YOUniverse Deluxe ATM Bank Machine
We had the same issue -- the name could be reset, but not the pin could not.
Finally, I realzed that when it is reset by using the reset button or the batteries, the PIN is reset to the factory default of 1234. Don't try using your old pin at this point -- enter 1234 as the pin.
Once you have the bank working again, theoretically you can reset your pin to whatever you like by hitting enter twice. I say theoretically because we're sticking with the factory default for now.
Hope this helps.
Nov 07, 2008 | Summit Electronic Money Jar
CDC-X304 in permanent DEMO mode
I HAVE SAME PROBLEM. AFTER I REPLACED MY DEAD BATTERY MY AIWA CDC-X304 IS STUCK IN THE DEMO MODE. ONLY CD WORKS BUT ALL BUTTONS ON FACING DO NOT RESPOND. ANY SUGGESTIONS HOW TO RESET.
Jan 16, 2008 | Aiwa CDC-X304 CD Player
I need reset pin number
To reset your pin on your base station, you push Menu, scroll to System Settings, DON'T PUSH SELECT, push * 6 5 # That will reset the pin.
Aug 17, 2007 | Siemens Gigaset 8825 Cordless Phone
Discovery Channel Atm Bank Logo
433 people viewed this question
Top Discovery Channel Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Discovery Channel Toy Expert? Answer questions, earn points and help others
