Question about Honeywell Programmable Thermostat Heater
The display reads HOLD -AC. My AC will not come
The display reads HOLD -AC. My AC will not come on. I've tried adjusting the temp but nothing happens.
    Problem Solver:
  • 5 Answers
Try turning the hold button off as this may work.
Posted on Jul 19, 2009
Installed a new control board in a Whirlpool G15FSAXVY04, display reads PE0 000 flashing, what should I do next
You need to program the control board to match the refrigerator. Look for the serial plate and locate the number following "Code". That number is the program code and you will need that value.
1) press and hold Door Alarm keypad.
2) Press and hold the Freezer Temp Down keypad.
3) Release the Door Alarm keypad and wait 3 seconds. The refrigerator display should read PE - programming mode.
4) Press the Freezer Temp Down keypad to confirm that you are in the programming mode. Compare the Code number displayed to the one you recorded off the serial plate.
5) If they are the same, press and hold the Door Alarm keypad for 3 seconds to exit the programming mode.
6) Otherwise, press the Refrigerator Temp Up or Down keypads to change the first digit in the program code to get the correct value.
7) Press the Freezer Temp Up keypad to move to the next digit in the program code to adjust that. Use the Refrigerator Temp Up/Down buttons.
8) Repeat steps 6 and 7 until all of the digits match the Program Code from the serial plate of your appliance.
9) Press and hold the Freezer Temp Down button until the display begins to flash to save the code. If you hear a beep, the code is incorrect and was not saved.
If you heard a beep, return to steps 6 and 7 to correct the program code. Then go to step 9 again. If the code was saved, press any keypad to exit the programming mode.
I hope this helps.
Aug 08, 2015 | Whirlpool Washing Machines
1992 buick cenyury dual climate controls with settings both full hot with digital display reading 90 with vehicle warm restarting first comes out hot after running for a few mins then 90 degree digital...
look like the program is not working. if the set temp, is lower than the real temp, heather should come on.
if the set temp is higher than the ambient temp. the ACC should come on.
I will try one first, then setup the other.
Jan 21, 2014 | 1992 Buick Century
2012 chevy captiva Ac not working. My ac just stopped working. I've checked all fuses and they are fine. The dash display has a reading of the outside temp and it only displays three dashes. Any...
there are 2 pressure control switches that control the ac clutch operation. One is to stop the compressor if the head pressure go too high and the other is to stop the compressor if there is not enough gas in the system.. Have a ac mechanic check it out as you may have a leak somewhere.
Jul 21, 2013 | Cars & Trucks
The actual temperature of my oven does not agree with what it says on the digital readout in the clock area. I have been told that you can adjust the reading of the clock, but I cannot find the service...
Press bake and set temp. to highest setting on some it's 500 on others it's 550 aftef setting to highest bake setting. Press and hold bake button until 00 is displayed,use up/down arrows to adjust in 5 degree incriments to plus/minus 35 dergees . ONce you've adjusted it push cancel/off button and you adjustment will be stored even if power loss and clock went out.
If your temp is more than 35 degrees off the clock needs to be replaced
Aug 16, 2011 | Ovens
I have a white Rodgers ac thermostat and the temperature in my apartment stays on 88 no matter how low I set the temp. If I turn it off, of course it gets even hotter. This started happening when I pressed...
I'm not quite sure I understand what you have done but, make sure your compresor(outside is running and, that you don't have the thermostat set to "fan". You want the display to show "cool" and then adjust your temp. It sounds like you have the system set to fan and not cool. Provide me with a model number and I will see about getting you a manual.
Jun 04, 2011 | White Rodgers 0754-1 Electric Water Heater...
Trane XT300 thermostat reads HOLD-AC. Unit will
by simply turning power off to furnace or air handler may not work but there might be a reset button in the t-stat. remove the faceplate off of the t-stat it might be in their.
Aug 16, 2009 | Heating & Cooling
-AC appears in the display of chronotherm III
I have had the same problem- twice. It was a similar but different problem each time. The -AC means the ac control voltage isnt making it to the thermostat. In my case both times it was a switch in the control circuit that wasn't closing properly. The easiest was the front cover switch. If the front cover is removed from the furnace or has vibrated loose, the switch will open, preventing the furnace from running. The other instance I ran into was a flow switch on the exhaust blower which ensures the there is flow OUT the chimney. The switch wasn't functioning, so the furnace wouldn't start. The blower would come on for a short time, but the burners wouldn't light.
Hope this helps,
Dec 12, 2008 | Honeywell Programmable Thermostat Heater
Oven Temperture adjustment
On my Epicure, you are supposed to press the bake selector pad then press the + button to set the temperature to 500 degrees or higher.  Then hold the bake button for 5 seconds.  The temp display is replaced by 00.  Release the bake pad and use the - or+ buttons to adjust the temperature in 5 degree increments.  When finished push cancel (or just do nothing).  Good luck.  I tried this and my oven kind of went haywire.  It decreased the temp by much more than the 10 degrees I had set it too.  May be something else wrong with my oven though?
Nov 18, 2007 | Dacor Epicure ERD36 Dual Fuel (Electric...
Heating & Cooling Logo
409 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
