Question about Kenmore Elite 45986 Front Load Washer
Rubber boot and spring need put back in
How do I put the rubber boot and spring back in the the front load kenmore elite he3 washer?
  • Anonymous Mar 23, 2014
    spring came off, cant get it back on
  • 5,911 Answers
Follow these steps:
1. Install the door bellow (rubber boot) back over the frame of the door opening ensuring you fit it snugly all the way around the door frame opening.
2. Insert the wire hoop in the rubber groove of the bellow where it fits around the outside perimeter of the door frame. Begin at the top of the door with the wire spring pointing towards the bottom.
3. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place.
It may be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 19, 2009
  • Jeff Rockwell
    Jeff Rockwell Jul 19, 2009
    The spring clamp has no means of tightening, so you can't "overtighten" it.
    President:
  • 1,273 Answers
The rubber boot presses on the rim, and the spring clamp fits in the groove behind it. Don't overtighten.
--W/D--
Seems load is out of balance
Your washing drum is spring balanced and your
motor has rubber shocks to keep it balanced so check
both for damage. _( cracks in rubber shocks and breaks in
washing drum spring or springs ) Also springs or rubber
shocks are no longer fastened to motor or chassis.
Feb 11, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore washer HE3 broken door latch. How do you replace
Unplug unit then You can open the door, then remove the spring loaded clamp that secures the door boot (rubber) to the front panel, carefully pull the door boot away just where the door latch is (no reason to completely remove) remove the 3 screws securing the door latch to the front panel..Then reach behind the panel and pull the latch towards the opening the give just enough wiring to do so undo the 3 wiring connectors to the latch assy. then pull out the rest of the way Reverse the procedure to reinstall
Dec 29, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3 front loading washer, model 110.45872400 - completely drains and runs correctly but sometimes an hour later there will be water in the tub
Your water inlet valve is leaking it needs to be replaced.You need to remove the top to access it.There are screws along the back edge holding it on.
Jul 24, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore He3 washer manual required
See the following Sears site for on line (PDF) manuals
http://www.managemylife.com/mmh/owner_manuals/search?query=110.45872400
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore 'elite' HE3 front loading washer
I have the same problem. Nothing works fcfor the mildew. i have bleached it, used simple green and used baking soda. That washer is the biggest piece ever!! Good Luck!
Jul 06, 2009 | Kenmore Elite 45986 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front load He3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Feb 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 will not hold water leaks into the pedestal
run you fingers into the door boot and inspect for holes ,, that probably what it is ,,,,,,big tear
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
290 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
