Question about Toshiba TLP450, TLP451, TLP650, TLP651, TLP670U, TLP671U Projector Lamp - TLP-L6 Projector Lamp
Toshiba TLP651 Reset Lamp time - Toshiba TLP450, TLP451, TLP650, TLP651, TLP670U, TLP671U Projector Lamp - TLP-L6 Projector Lamp
  • 2,237 Answers
Menu, settings, lamphour reset.
Posted on Jul 22, 2009
Toshiba 62mx196 TV just replaced lamp...screen appears to come on then whole set shuts down.....any ideas
A lamp time reset might help you. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Type in "Lamp Reset" in the search box at top right of the display window to get gathered related posts.
Apr 07, 2016 | Toshiba Televison & Video
Reset the lamp timer TLP560
can anyone help me to reset my toshiba tlp 560 lamp
there must be a command or conbination of buttons to do this
best regards
Aug 04, 2014 | Toshiba TLP560 Projector Lamp 195Watt...
I heard a pop on the Toshiba rear projection TV (model #62hmx84) and immediately lost the picture
Sir the problem of your unit is the lamp try to replace it it is much better to use a gloves and wash your hand after replacing the lamp because this lamp contains mercury. follow this steps.
1. Unplug the unit to main ac outlet. Remove the bulb housing cover from the back of the TV. Using a screwdriver, carefully remove the cover to reveal the old bulb. Using a cloth, remove the bulb from the TV by first unplugging it from the wiring harness. Carefully rock the harness back and forth until it comes free from the bulb. Push in the bulb slightly and turn it a quarter-turn to remove it from the bulb housing.
2. Install the new bulb. Do not touch the new bulb with your fingers, as any grease or fingerprint from your hands will damage the tiny mirrors in the bulb. Instead, carefully handle the bulb using the cloth. Insert it into the bulb housing and secure the door. Test the unit. Plug in and turn on your Toshiba TV and make sure that the new bulb is installed properly and that the image looks crisp.
3.
Reset the lamp time counter. Each Toshiba TV comes with a lamp hour meter stored in its software. If you do not reset the lamp timer, the unit may stop operating when it gets to a certain time (refer to your manual because each Toshiba TV is slightly different). To reset your Toshiba lamp timer, turn off the TV, wait 10 seconds, hold down the "on," "menu" and "input" buttons on the remote at the same time, and turn the power back on. A yellow light should appear in the bottom corner of the TV indicating that the lamp timer has been reset.
Hope this help good day and best regards.
Sep 23, 2011 | Toshiba 62HMX84 62" Rear Projection HDTV
I would like to know how to reset the lamp life for a Toshiba TLP670 projector. Thank you.
I checked the manual and it does not specifically state the method you should use. If you want to download a copy here is a link http://www.allprojectorlamps.com/Toshiba-Projector-Manuals_ep_64-1.html . There is no charge for the downlaod and they don' ask you for your email adress or anything. The reset instructions are on page 42.
Aug 16, 2010 | Toshiba TLP450, TLP451, TLP650, TLP651,...
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Toshiba Projector TLP 651 lamp problem
yes resetting the lamp hour might be the issue but not necessarily. It could also be a temperature issue as the fan (s) might have stopped or a temp sensor issue is faulty. check your manual for resetting lamp hours. Regards Kevin Andreassend www.iceav.co.nz iceavtech@gmail.com
Oct 28, 2008 | Toshiba TLP450, TLP451, TLP650, TLP651,...
Toshiba tlp670u
This is due to filter problem you can clean the filter other and put it back this one reason.
Another one it might me problem with cooling fans any one of the fan speed will slow or failed. Please check the same and replace.
Regards,
prakasam
Mar 05, 2008 | Toshiba TLP450, TLP451, TLP650, TLP651,...
805 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
