Question about Poulan 1630 16" Chain Saw
I have a Poulon chainsaw problem. I bought it of a "E-bay'' type site. Have replaced the starter cord, put a new fuel line in, replaced the fuel filter and serviced the carb. I've adjusted the H and L screws as best i could, but the idling seems to fluctuate. Goes from idling too fast too just dying. Also when i got it to run for a little while and started to use it, the chain would go tight on the bar obviously adding extra drag on the motor, causing it to stop...., can you please help ?
  • 154 Answers
Buy a husky
Posted on Aug 01, 2009
Poulon pro 18" smoking
The only way a two stroke can smoke is either it is running far too rich ( possible blocked air filter ) or there is too much or incorrect oil in the fuel, if the oil tank for the chain is sepereted from the crankcase by a gasket, it maybe the gasket leaking and allowing chain oil into the crankcase.
Sep 10, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My Poulon Pro 17 will not start; it has new fuel lines, new spark plug, new filter, and clean fuel. What have I overlooked?
Got spark? Take the plug out but leave it connected to the plug wire, touch some part of the threads to the metal near the hole in the engine for the plug, turn it over a few times either with the pull cord or with a starter, and see if you get spark, if not, could be ign. coil module, bad plug wire, or bad wiring to the ign. coil module.
Jun 01, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Pull line broke.
Remove the starter housing from the engine, then unwind the rest of the cord from the reel. With both parts of the cord, measure the total length of cord plus some extra for knots. Take one of the remnants with you to a saw service shop for replacement cord purchase. You might even take the entire starter mechanism and have them rewind the cord for you if you don't feel comfortable about installing the new cord. When done, just reinstall the starter on the saw and attempt a start. Good luck!
May 17, 2010 | Garden
Fuel line replacement on Poulon 2050 14 inch Gas Chain Saw
First rule is to replace only one line at a time. Needle nose pliers is the only tool you should need. Replace the fuel line from the filter in the tank to the carburetor by removing the filter from the line, extract the line out of the tank, and remove the other end from the carburetor. Use the old line to measure for the replacement. Measure the point where the old line passed through the tank wall down to the filter connection. Mark this point on the new line, and push the line into the tank far enough to attach the filter (which you have checked for plugging), then pull the line back out to the mark. Make sure that you use the proper line for this connection as the filter must flop around to the lowest tank level so that the saw doesn't run dry of fuel when operated on it's side. The other connections are straight forward--just replace one at a time. Don't be stingy in making looping turns as you don't want future kinks. Hope this helps!
May 02, 2010 | Poulan 14" Chainsaw
My poulon chainsaw will not stay running
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to seedaylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Nov 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chainsaw stalls in horizontal position
Inside the fuel tank is a hose with a weighted fuel filter on the bottom. If it is hung up or has hardened with age when you tip your saw this pickup my go above the fuel causing the saw to starve. You should hear the saw sputter and surge before it dies. Remove to fuel cap, insert a blunted rod and move it gently up toward the opening, the hose should be visible and this should have freed it if stuck.
If it suddenly quits running when tipped I'd check the electrical connections, under the starter housing.
If you find nothing and the problem continues time for a trip to your friendly local chainsaw shop. GL
Lou
Aug 27, 2009 | Garden
New ms230 stihl chainsaw won't start
Sounds like its flooded pull the plug and run pull it a few dozen times to dry it out. then try again
May 26, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Having hard time with new poulon 18" chainsaw starting.
Since you have good spark and good gas the only things left to check are the air filter and the carbeurator. If the air filter is dirty, replace it. While you are at the auto parts store also pick up a can of a gasoline additive called seafoam which will keep your carb. clean. Finally get a can of spray carb. cleaner and put a couple short squirts directly into the air intake which is right there when you remove the air filter.
May 20, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 1630 16" Chain Saw Logo
83 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
