Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Westinghouse LCD loss of vertical hold purchased 2006
This TV looses vertical hold , sometimes a power on/off solves it,
it will work for about 15 minutes then stop again.
Also a cloud of Jesus that has slowly over the years migrated across the screen. Maybe I'll just Ebay it. I suspect a screen defect, tech support refused to listen and suggested I use a pixel fix program. (for the whole screen!) sillyness
sk-32H590D
5070A711000163
anyone have a service manual (do they make these anymore) for this or a similar set?
please post a link
thanks
SOURCE: Westinghouse SK-32H540S LCD TV Turns Itself On - Appears Random
turn the timer off.
Posted on Jan 27, 2009
SOURCE: Flickering/jumping picture
I HAVE THE SAME PROBLEM. TV WAS FINE UNTIL A FEW MONTHS AGO. OF COURSE ITS OUT OF WARRANTY. FROM WHAT I HAVE READ, AND BEEN TOLD, IT IS THE POWER SUPPLY TO THE UNIT. IT IS DEFECTIVE, OR IT OVERHEATS AND TRIES TO SHUT DOWN. A LAW SUIT IS IN PROGRESS AGAINST WESTINGHOUSE TO RESOLVE THIS MATTER. KINDA REMINDS ME OF THE XBOX 360'S WHEN THEY CAME OUT. ALL YOU CAN DO IS TAKE IT IN FOR SERVICE. OR, YOU CAN KEEP TURNING IT ON AND OFF, LIKE I DO. I HAVE HAD THIS TV ON ALL NIGHT BEFORE WITH NO PROBLEMS. AS SOON AS I START CHANGING STATIONS, OUT IT GOES. GOOD LUCK. WESTINGHOUSE WILL NOT EVEN EMAIL ME. I HAVE TRIED SEVERAL TIMES TO CONTACT THEM. I HAVE HEARD FROM THE LAW FIRM IN CALIFORNIA THAT IS GOING AFTER THEM. GO ONLINE, AND JOIN THE CRUSADE.
Posted on Apr 08, 2009
SOURCE: can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Posted on May 08, 2009
  • 105 Answers
SOURCE: i have a westinghouse sk-32h240s whin i retune it
No. Everytime you rescan channels it will dump any previously saved channels.
Posted on Jun 23, 2009
seawizz72
  • 9 Answers
SOURCE: No power on Westinghouse sk-19h21os flat screen monitor tv
I found a 2200microfarad @ 10v capacitor in the switching power supply that was bad. In these supplies, precision is crucial and tiny changes in the circuit will make them fail. Good luck !
Posted on Jul 25, 2009
TX-52F480S lines
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Oct 11, 2012 | Westinghouse TX-52F480S 52 in. LCD TV
TV has vertical folding of picture and loss of vertical hold.
Hello
The vertical output section of your Jensen TV is faulty. Usually this section has an IC circuit. Check the solder terminals of that IC for loose contact. This IC sill heatup while working. Repeated heaning and cooling will make ths solder terminals to get loose. It is very difficult to detect the loose soldering; as thay may be microscopic in size. Just resolder most of the suspected solder terminals by applying a little more solder, without making any solder bridge in between them. This must solve your TVs problem. Check the electrolytic filter capacitors also. Replace them. It won't cost more. OK.
Jun 24, 2011 | Jensen J53-BW 5 in. Portable Television
32" LCD tv w/built in DVD mounted on wall. screen will not hold picture - looks like vertical or horizontal hold needs adjusting, but cannot figure out how to adjust. happens when using DVD or VGA...
Vertical and horizontal adjust went out with black and white TV pretty much.I remember those days too...what would kids nowadays do???lol.Anyhow,the fact that it clears up sometimes when you slap it should mean that the screen is fine.Something on the circuit board may need repair.Unfortunately,I have searched for diagrams for TV's online many times and only authorized shops have the access required.I just checked westinghouse,not even a way to sign in if I were a reapir shop.So,needless to say, a shop will have to check it out.Sorry That's all I can suggest and good luck!
Aug 05, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Vertical colour bars
The problem is in the LCD controller board is overheated because the power supply unit is at the bottomof the TV and the heat rises upward to the vent on the top of the TV. You can verify that is hest problrm by running TV with the back removed and have a small fan blowing on the top secdtion of the TV where the LCD controller is. This how I fixed my scrambled picture after warm up (I added heat sinks to the IC on the LCD controller board) : http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
You can try it if the board was not badly damaged already by the heat. My has been running great for over a month now.
Feb 04, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Circuit diagram Samsung LE23R88BDX - LCD TV
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
Feb 24, 2009 | Samsung Televison & Video
TV shutting off
try this part first 5600110347 you can get it at www.vancebaldwin.com
Jan 31, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse 27" lcd hdtv
My Wesinghouse 27" lcd hdtv jumps and vertical hold is out of control after being on 15 mins. The cable company checked the connection and it is clean. We did not damage the tv. It has been doing this since we got it. We did not get a service contract. Sometimes the screen goes black with a small rolling picture on top. Help me please. Can the maufacter still help us?
we lost all the papers when we moved.
Jan 27, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
124 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
