Question about Canon EOS 40D Digital Camera
CF Card is not formatting. When I try to format it, the camera says. "Cannot format. Change the CF card." - but it can not read any card
  • Canon Master
  • 4,738 Answers
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see the following: http://camerarepair.blogspot.com/2009/06/fixing-compact-flash-memory-card-error.html
Posted on Jul 19, 2009
5 Suggested Answers
camerawes
  • 36 Answers
SOURCE: CF card error replaced the card and tried to
More than likely one or more of your CF pins in the camera are bent/broken. This is a very common problem. Most repair shops will charge between $150-$200 for this repair.
Hope this helps
Wes
Posted on Sep 10, 2010
SOURCE: I installed a new cf
Check if you're using a compatible CF card in the Camera. You can look in the user manual of the Camera to check for the compatible CF cards.
If the CF card that you're using is compatible but not working in the Camera then try using the card in other Camera to determine if the issue is with the card.
If the Card works normally in other Camera or device then reset the Camera to the original factory settings.
Even after resetting the Camera to the original factory settings if the CF card doesn't work in the Camera then you may try using any other compatible CF card to determine if the issue is with the CF card reader in the Camera.
Posted on Oct 30, 2009
  • 126 Answers
SOURCE: Unable to format CF card
Try formatting it on your computer...make sure you are formatting "that" drive and not your C drive.
Posted on Mar 19, 2010
SOURCE: My Canon 40d keeps saying'
My 40d keep saying the cf card is not formatted. I used three different cards and it says the same thing. Is it anything I can do to fix this problem.
Posted on Apr 07, 2011
Err cf
Try formatting the CF card in your computer and if it can be done successfully, return to the camera and try to format it in the camera. If not, then the card is bad or it is too large for the camera to read. Some older cameras have limits to the sizes of cards they can read.
Sep 27, 2014 | Canon Rebel XT / EOS 350D Digital Camera
When isert flash card i get err2 sign
According with the manual:
Err 02: There is a problem with the CF card. Do one of the following: Remove and reload the CF card, use another CF card, or format the CF card.
Try formatting the CF card in the camera, if that doesn't work use a card reader to format it in your PC then format it again in the camera. If that doesn't work try a different CF card.
Keep us updated.
Mar 22, 2011 | Canon Cameras
I took the CF card out of my Rebel XTi EOS camera to look at the pictures on my computer. When I put the CF card back in the camera I am getting the message "There is a problem with the CF card. ...
This is an old posting but I'd like to comment that once the memory card is used in a computer it won't read in the camera again until you format the memory card. Make sure you have all your pictures on the computer before formatting the memory card. A memory card must be formatted in the camera it is going to be used in.
Jan 01, 2011 | Canon EOS Rebel XSi Digital Camera
When I insert the CF card, and then turn the camera on, I get a reading that the card needs to be formatted. I then try to format the card, and it says that the card cannot be formated. I looked inside,...
If trying another card doesn't work then reformat your CF card in your computer choosing a Quick Format option. Then place it in the camera, do an immediate card format in the camera. If you've got images on the card now DO NOT SHOOT ANYTHING on the card before running an image recovery program like Sandisk RescuePro. As long as you don't shoot anything new on the card RescurPro should recovery all the existing images.
Dec 25, 2010 | Canon EOS-5D Digital Camera
My Canon 40d keeps saying' CF card not formatted Format card with this camera'. I tried to do that but it says ' Cannot format Change the CF card. I have 6 cards and I've tried them all with the same...
Nov 29, 2010 | Canon EOS 40D Digital Camera
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
Mar 19, 2010 | Canon EOS 40D Digital Camera
I installed a new cf card in my canon camera. It says "card not formatted" and when I try to format it, it says "cannot format. change CF card". what gives?
Oct 30, 2009 | Cameras
Error 30
The "E30" error code is displayed when reading/writing data on a CF card has failed. Especially, the error code "E30" may appears when you tried to remove a CF card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the CF card with your camera Try to format the CF card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting CF cards. Also, please note that formatting a CF card will erase all data on the card. Once the CF card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the CF card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the CF card.
Aug 29, 2005 | Canon PowerShot A310 Digital Camera
Canon EOS 40D Digital Camera Logo
613 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
