Manual for Kaon stb - Televison & Video
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
Kaon remote code
0296,0299,0291. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Feb 24, 2014 | Sharp Televison & Video
Manual for tivax stb-t8 converter box
http://michley.net/STB-T8.User.Manual.pdf
Nov 13, 2011 | Fulltone TIVAX STBT8
Need to know how to record a vhs to a dvd on a zenith allegro abv341 or where to get a manual
Manuals can be downloaded here in pdf format (Needs a pdf reader such as Adobe Reader to view the document.)
http://136.166.4.200/contents/STB/ABV341.htm
Direct link to owners manual
http://136.166.4.200/contents/STB/ABV341/ABV341_Owners_Manual.pdf
Mar 02, 2011 | Zenith ABV441 Player
I need a information Manual for my LENOXX DBT please. The Phillips No's are 2480635 29970323.
I'd love to help you - and I probably can - but you are going to need to provide a little more info.
Firstly, I'm not exactly sure what a DBT is - my educated guess would be that you need a manual for a set-top box / digital tuner. These usually have DVB-T marked on them (Digital Video Broadcasting - Terrestrial).
I can supply manuals FREE for some models of Lenoxx digital tuners but not all of them. Lenoxx charge AU$15 for these so hopefully I can supply the one you want - assuming this is what you are actually requesting.
If you can let me know the model number of the device you require a manual for, I may be able to supply one. For Lenoxx digital tuners, the model numbers generally start with STB (meaning set-top box) and then 3 or 4 numbers, e.g STB-300, STB-500, STB-800, STB-1200.
If you need a manual for some other Lenoxx product, then please supply a model number for it. These can usually be found somewhere on the product, often in small letters on the front panel or on a manufacturer's sticker on the back.
I am also a little confused to the relevance of the Philips numbers you listed. I'm assuming they relate to your TV, but they are definitely not model numbers and therefore could relate to anything. They are most probably serial numbers of some kind, in which case those numbers are only relevant to your TV and as such it is not possible to determine which product they relate to.
If you need information for your TV, again you are going to need to provide a model number. You should be able to find this somewhere on the back of the TV.
Please clarify exactly what you need and I'm sure I - or someone else here - will be able to assist you.
Regards,
BElectric
Jan 14, 2011 | Philips Televison & Video
Can't see or listen to stb when changing input source and go back
Maybe the STB detects that there is nothing "listening" on the other end of HDMI and turns its output off. Does it work again if you turn off+on the STB without touching receiver?
Jan 18, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
How to access the usb port on a samsung le32b450
according to the user manual,the USB port is intended only for software upgrade, here are some of the supported inputs for your TV : VCR / DVD / Cable STB / Satellite STB / PVR STB / AV Receiver / Game / Camcorder / PC / DVI PC / DVI / TV / IPTV /
Blu- ray / HD DVD / DMA
Aug 29, 2009 | Samsung Televison & Video
I own a Go-Video DVD-VCR Player, Model DV3140. I recently switched to Verizon service and find that I can no longer olay my DVDs/VCRs with the Fios System. Can you assist me in how to program my player...
Hi
You can reprogram it by following these instructions--
Power turns on or off both your STB and TV when you are in STB mode. (If you have a DVR STB, the DVR will continue to record scheduled programs when off.) However, you can reprogram how the Power Key works. If you want the Power Key to control multiple devices at once --
1. Press and hold the STB key.
2. While holding down the STB key, press OK.
3. Release both keys. The Device Keys will blink twice.
4. Press 9 - 7 - 7. The STB key will blink twice.
5. One after the other, press each Device Key you want the Power Key to control, in the order you want them to turn on or off. Each selected device Key will blink twice after it is pressed.
6. Press OK when done. The STB key will blink three times to indicate success in programming.
For example, to program the Power Key to turn on or off your TV, AUX and
STB, in that order with one press of the Power Key, press [STB+OK], [9-7-7],
[TV], [AUX], [STB], [OK].
These are the codes for GO Video DVD Player--
Go Video 0771, 0768, 0810, 0896, 1071, 1102, 1185, 1757
You can view/download the manual for the fios from this link--
Verizon fios remote programming
You can visit this link for more information--
Verizon FiOS Troubleshooting
If you want to doanload the user manual for your verizon set top box you can get it from here
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Televison & Video
32lg30 mkj40653801 codes
A printable manual with codes can be found at http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3252
Jan 21, 2009 | LG 37LG30 37 in. LCD HDTV
Televison & Video Logo
780 people viewed this question
Top Televison & Video Experts
Electro Med Services...
