Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Kitchenaid bottom drawer freezer is making frost or ice flakes inside. Why?
  • GE Master
  • 1,606 Answers
If frost is front towards door then the seal is not sealing well . Use a hair dryer on portion which is not touching cabinet . Also check for split somewhere on gasket & if found , replace gasket . If frost on the rear wall of freezer , then a defrost problem could be starting in which the fridge section would be warming up . However , bottom freezers are known for their gaskets not to seat properly .
Posted on Jul 19, 2009
How to clear out the drain tube on a kitcheaid refrigerator
Freezer has been leaking water at the bottom. I opened the drawer/door and removed the bins, there was a small amount of ice formed on the bottom at the back, I broke it away and poured a small bit of warm water in the black drain hole. the next day the bottom and rear are full of frozen ice and it is difficult to open the drawer/door to the freezer. Everything is covered with frost. Help!
Jun 18, 2014 | KitchenAid KBFA25ER Bottom Freezer French...
Sub Zero 700 TC with two freezer drawers on bottom. Ice sheet is forming on the bottom below the drawers and causing the drawer to stick. I have defrosted the freezer with a hair dryer and thought this...
How are the ice cubes? Are they normal size or hollow? I was wondering if some of the water was not making it into the ice maker and causing this issue. Is there any frosting issue not mentioned? Any water droplets on or around the back wall of the unit (inside)? I am a service tech certified and would like to know more about this issue. Have you cleared the drain completely, meaning after you de-iced unit, did you use water to verify the drain was cleared?
I you like to know more, so I can direct you in solving this issue.
Sep 22, 2013 | Sub-Zero 700TC Bottom Freezer Refrigerator
Frigidaire refrigerator/freezer side by side--compressor keeps running
Most problems with side by sides frosting up is due to failure of the defrost heater in the bottom of the freezer section behind the panel inside.
Jun 16, 2012 | Refrigerators
Frost in freezer
You can switch off the freezer from time to time to let the ice to melt.
Of course the too much accumulation of ice will affect the freezer.
Mar 17, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
Ice forming in the bottom of the freezer. eventually melting and ending with water running on the floor from both corners of freezer
Check the seal on the door and make sure it is "sound". Pay particular attention to the bottom or underside of the freezer door / drawer. Make sure nothing is preventing a seal between the fridge case and door. Misfigured, distorted or otherwise damaged seals can cause frost build up as you describe. Clear any objects / replace damaged seals found.
Sep 06, 2011 | KitchenAid KBFS25EVMS Stainless Steel...
Water standing under bottom drawer
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Dec 27, 2010 | KitchenAid KSRG25FKSS Side by Side...
Water dripping from the bottom of the freezer drawer
Your unit has auto defrost. Remove the food from the bottom section and see if you have some frost/ice blocking the bottom vent. If it is blocked, using a hair dryer....remove the frost/ice and then you may have to remove the inside rear panel to unblock the drain hole behind the panel.....
Take care ......
Aug 10, 2010 | Sub-Zero 650 / O Bottom Freezer...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
I have a bosch frost free fidge freezer. I have noticed that there is a layer of ice under the bottom of the bottom drawer in the freezer. What is causing it? Thanks
defrost drain is blocked probably with ice
remove back panel inside freezer and drain is at bottom. melt of any ice with a hairdryer and follow up with hot water till water flows away freely. needs patience
Sep 07, 2008 | Bosch Refrigerators
Refrigerators Logo
288 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
