VIZIO VW42L-hdtv10a was not working, bought another, same model, had a damaged screen, but both had the same system in them, replaced both boards, and now, it stays on! but is stuck in the test mode, I DID push the button on the viedo board, and thats when it started. dont know how to get out of the test mode, please help, rick
    President:
  • 1,734 Answers
Everything you need to know about your TV is described here
also the different modes and how to enter or leave them. This fits also to your model.
Posted on Jul 19, 2009
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
VW42l. Why is there a black screen with sound?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 25, 2015 | Vizio Televison & Video
Vizio vw42l hdtv10a black screen no sound..please help!!!
The fact the Remote and the side buttons don't work may indicate a microprocessor problem in the set---some sets do have a option that locks out remote and buttons on set--
If you have not tried it, unplug set for a while and plug back in as if a power loss happened to the set this may allow the set to "reboot" and operate again.
Inverter will not affect the remote or buttons on the set. (Its like saying my car has a flat tire, will it stop the motor from starting?)
My best bet would be if the remote/buttons issue is cured the set will be fixed.
Apr 14, 2012 | Televison & Video
Hello, I have a vizio vw42l hdtv10a that I got for free. The guy I got it from said he heard a loud "zap" noise then the screen went black. When the power button is pressed the unit come on for...
It is quite possible from your report that an ELECTROLYTIC CAPACITOR has failed. So remove the power and use a good observation lamp to check of BULGED or bursted capacitors-- as the noise was heard earlier. Look for spilled eleectrolyte on the PCB and if so the entire PCD must be washed- use petrol and dry.
Also the damaged capacitor must be changed and please do not switch on with a fault like this as the circuit may be damaged.
Jul 29, 2011 | Vizio P2 42 in. HD-Ready Plasma Television
42" vizio vw42l - no picture or sound
If the backlights for the screen do come on and you also have 12v and 5v feed the main board then it does sound like the mainboard will need to be replaced.
Nov 28, 2009 | Vizio VW42LF 42 in. LCD HDTV
Vizio vw42l, the vizio light turns from ornage to
Does LCD screen backlight come on? If so proceed....
USE:CAUTION WHEN DOING THIS....
Try this if repairing yourself...find power supply, small board with no cover over it...check voltages on output pins/plug/connectors (white plugs) three in a row...
1 Plug has 24Volt supply..1 has 12Volt supply and 1 has 5Volt supply when read to ground (screw that holds board in) if you have these voltages it's a safe bet it's the main control board...I just replaced mine and it fixed a problem like yours.
Jul 10, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio GV42L 42inch LCD/HDTV
there are several possibilities. first if the unit comes on and the "VIZIO" light turns white, but no picture or sound, then the main control board is most likely the issue. could be the LCD control board(s) depending on model one or two. and ultimately could be the power supply on the upper side....if the "VIZIO" light does NOT turn white, the whole power supply unit is out. after that, would have to scope the circuits to find out. Seems that the control board is the most common and tends to happen on many different sizes. new board will be around $350.00. Might get lucky and find a used one, but it MUST be EXACT part or it wont work right. if you dont find one or want to sell yours for parts, id be interested in the screen. can reach me at kmarlin@grandvalleygolfclub.com. thanks, keith
Jun 27, 2009 | Vizio GV42L 42 in. LCD Television
Vizio 42" LCD Screen (VW42L FHDTV10A) Screen is cracked
i have a 42" cracked vizio screen, where can i find a replacement screen?
Jan 17, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
Electro Med Services...
