Question about Magellan MAESTRO 3100 98083401 GPS Device
Updating problem I wanted to update my firmware, and now my GPS does not work, except to show the Magellan sign and nothing happens beyond that.
    President:
  • 1,111 Answers
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Posted on Jul 19, 2009
  • Ben Dover Jul 19, 2009
    here are a few key points, but read the full update guide before trying the update again.
    hope this helps
    NOTE: This update is COMPATIBLE ONLY with Windows® XP.
    Before Beginning:
    Check to make sure you have everything required for updating your unit:
    • Magellan Maestro 3100 GPS
    • PC running Windows XP
    • A Blank SD memory card (16 MB to 2GB)
    • USB cable
    • Paper clip or similar object (for resetting your unit)
    EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
    1) The battery of your Maestro 3100 must be fully charged before beginning the update.
    NOTE: It takes between 3 and 4 hours to fully charge the battery with
    your vehicle power adapter. Check System Settings to ensure the battery
    is fully charged.
    2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
    a. Insert a blank SD memory card
    b. Select User Options
    c. Select Backup and Restore
    d. Select Yes to confirm
    3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
    4) Close all other applications while performing the update.
    5) Disconnect all Pocket PC devices from the USB ports on your PC.
    6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
    7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
    Update Process:
    1) Launch the Magellan_Maestro_3100_2_18.exe file.
    2) Select Next on the Welcome screen.
    3) Turn on your Magellan Maestro and connect the USB cable.
So my GPS was being updated when it suddenly shut off. Not it is stuck on a flashing Magellan logo screen and it will not go away. There is no reset button and the hidden menu doesnt work. I tried...
Contact Magellan for this issue. There are others also who had their Magellan GPS bricked while updating it. If it's a software fault it's serious - firmware update procedures should be fault free and thoroughly tested and shouldn't go wrong.
The problem usually can't be resolved without special factory tools to re-flash the internal firmware.
Jul 04, 2011 | Magellan RoadMate 1470 GPS Receiver
Cant not get watereays on explorist 500 in canada
You can try to update your GPS firmware.
Before you update your Magellan eXplorist 500 firmware or install a custom basemap, Magellan recommends that you backup all of your GPS data.
Click here to download the firmware update (Version 2.57)
Connect your Magellan GPS unit via the USB drive.
Double-click on the update file to begin the installation process.
Follow the on-screen instructions .
Jun 17, 2011 | Magellan GPS
How can I update my Magellan Maestro 3210?
  • Hi if you want to update the firmware just login to the website of Magellan and make sure that the GPS must connected when doing the update.
  • For the map update call the customer hotline and check if you can get a free map update or if they have discounts for map update.
  • If you have followup questions don't hesitate to reply to this solution.
Jun 15, 2010 | Magellan Maestro 3210 GPS Receiver
Magellan Roadmate 1470 screen froze at spinning clock
Same thing happened to me. It was working fine yesterday, until I arrived at my destination, then it froze and when I restart it, it stops at the spinning clock. I'm so mad at myself for not researching the update and finding out that this is happening a lot!!
I don't think I have my receipt. It will be interesting to see if Magellan charges me for THEIR mistake!
Dec 27, 2009 | Magellan RoadMate 1470 GPS Receiver
UPDATE MAPS ON MY MAGELLAN
According to Magellan at their website, a new map update will be available next month (sometime). There is a firmware update there now.  The firmware update works fine if you follow their instructions.....full battery charge etc.
Mar 31, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Magellan 4040 download problem
try to press the reset button on the left side next to the usb port with a small paper clip or toothpick and see what happens and chk on the magellan website to see for firmware update if it is do it and plug in powersupply and the usb and leave it alone and let it reset a few times until it says to unplug from the usb .also make sure it has a flash sd card in it so you do not lose your addresses.let me know what happens.
Mar 08, 2008 | Magellan Maestro 4040 GPS Receiver
GPS freezes when I need it to work!
i have a 800 also but it does not freeze because i make sure it is up to date on all firmware and software,if i was you chk out for updates on the magellan website2.gif after you register your unit then if ther is, which i know do the update and you will have no problems after that.let me know how it goes.
Dec 25, 2007 | Magellan RoadMate 800 GPS Receiver
Magellan MAESTRO 3100 98083401 GPS Device Logo
193 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
