Question about Panasonic PT-47WX49 47" Rear Projection Television
It turns on, and then after 4 seconds it sparks and turns off.
Please help with this problem.
  • Panasonic Master
  • 8,617 Answers
Where does the spark come from? Can you see it from behind the set when the power button is pressed? It could be solder related or a cracked bad flyback. Try to notice wheeit sparks from then let me know.
Posted on Jan 27, 2008
SNOW GIANT WONT START please help me turn it on
An engine needs compression, timing, an adequate spark and the right amount of fuel in order to start and run.
When attempting to diagnose trouble each one of those requirements must be checked in a fairly logical sequence and when all are present the engine will start. If the engine doesn't start and run then one or more of those requirements is absent.
A new spark plug correctly gapped wouldn't do any harm at all but as it fires using an ether spray it would indicate a lack of fuel is the problem.
The correct operation of the choke if it is a strangler type should be observable by looking down the carburettor bore.
Mar 14, 2017 | Garden
Engine cranks but doesn't start
Hi Donald, Im AL the owner of Big As Auto Repair.
Donald, sense you have a burning smell and a starting and running issue, I would start by checking all the wiring and connectors to see if they are burnt OR may have fell onto the exhaust somewhere and melted the wiring. Hope this helps and please visit my auto-repair-website here: http://www.bigasautorepair.com/
Dec 12, 2015 | 2005 Dodge Neon
Ride on mower
float in carb is stuck open or someone opened the set screw on the carb all the way,it is only 1 1/4 turns
Jul 21, 2015 | Garden
No spark from distributor
1990 , no spark at 1 spark wire pull? or all 4? or ?
what about the ignition coil, got spark there?
is the cam turning? does the rotor spin? cranking,?
if the EFI has power, DC 12v power. and all fuses good.
CEL lamp glows key on, is a good sign, on all cars.
and the rotor turns and the COIL is dead (ignition coil)_
then do the winkyblinky tests.
http://www.troublecodes.net/acura/
1: key on.
2: crack for 5 seconds.
3: release key, do not turn off key
4: read the codes from ECU directly.
bingo codes for no spark are.
4,5,9,15 (ask for help here)
the chart
yah gotta love OBD1, not fun at all but , im used to it.
http://www.troublecodes.net/acura/88-5991-96vlin/
if you get a code, we can go to the bad part easy
the FSM covers all this, in vivid details.
Mar 01, 2014 | 1990 Acura Integra Hatchback
I have a 1997 grand jeep Cherokee can u please tell me why the injectors will pulse and the coil not I have replaced the coil, cam sensor and crank sensor please help me thanks
I have no idea what you are asking. Start with are you getting fuel . Can you here the pump in the tank for about 5 seconds after you turn key on? Look down where carburetor would be is gas squirting in there when you turn the key and crank. Take off a spark plug wire off plug put an old plug in the wire brake of the bottom electrode and hold it 1/4 inch away from an engine bolt or ground and have some one crank engine should have blue spark.
Aug 23, 2011 | 1997 Jeep Grand Cherokee
My Viking Range top has 4 burners and the automatic ignition on the left two burners do not wok. Can hear clicks and gas but no ignition. Can manually lite them. Any ideas?
Sorry to read about your problem, I hope this helps you out.
your lite tube may be clogged, or take a needle and clean the hole's next to the lite tube on the range grills..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 19, 2010 | Viking Cooktops
2002 blazer crank but wont start
2 things that you have to check on no starts every time. Spark at spark plug and fuel. Turn key to run position and listen at gas tank for fuel pump to run you should hear a whining noise. This will only happen for 3 to 4 seconds then it will shut off until engine starts. You can turn key off then to run every 3 to 4 to listen for fuel pump. You may hear the relay click off in engine area even if pump does not run. Fuel pump failure is pretty common. If pump is running pull spark plug out or put a spare plug into spark plug wire and have someone crank engine set plug on engine and watch for spark. This will give you a starting point. Hope it helps.
Mar 30, 2010 | 2002 Chevrolet Blazer
Car died on road engine turn over but will not start
Try spraying starting fluid into the air intake, with the help of someone else starting the car. As they crank over the car, spray the starting fluid into the air intake. Do this for at least 15 seconds. If the car tries to start up the fuel pump has probably gone bad. When turning the key to the on position do you hear the fuel pump humming? If the pump is not humming the fuel pump is probably bad.
Mar 10, 2010 | 1992 Oldsmobile Cutlass Supreme
Car stalls out
Has anybody been working on the car latley or has it gotten the spark plugs or wires changed latley the clicking that you hear is normally spark plug wires going bad they ark a spark to the closest metal around them 1 way you might be able to see is pop the hood and start the car at night if you see it sparking then thats it just buy a set of wires there prob 40 bucks... I had alittle toyota and thats all it was its because there small 4 cylinder cars so something tiny will make the whole motor act up,, Check that and let me know ill help you out more with any questions please rate me
thanks,
Steve
Nov 11, 2008 | 2000 Hyundai Sonata
Panasonic PT-47WX49 47" Rear Projection Television Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
