Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
Hp cd rom dvd drive
Hi my cd rom dvd drive is not computer and when put cd or dvd it not open. where can i download it thanks.
  • Art Weber May 11, 2010
    Read your question over and rewrite it so it makes sense.
  • 358 Answers
Try this quick fix :
Get a screw driver, unscrew your machine and remove your drive. If you cant do this by yourself, just try and get a good technician to do it for you.
After this, power up your system normally without the drive connected.
Then shut down properly, and reconnect the drive, making sure that its firmly connected.
Then power on again and check it in the system BIOS if its now detected, then save and exit, then boot your system properly again.Then when the system boots, just right click on my computer, then properties, then select the hardwares tab, then click on device manager.
When you get to device manager page, try and locate DVD/CDrom Drives, then click on it, if your drive is there, then just right-click on it, and select uninstall, and after this, on that same page, click on 'Actions', and select "Scan for hardware changes". But if its not there. Just click on the "Actions, and Then select "Scan for hardware changes".
This should automatically out it back inside your My Computer page.
Hope this helps you out.
Posted on Jul 20, 2009
Hp pavilion dv2000, my cd/dvd rom is not working. the icon in my computer is not showing and when i put a cd or dvd its not reading. Thanks in advance for your help.
Hi, Assuming that the computer was functioning normally at one time when you had it and you did NOT buy it broken. It seems to be missing drivers that is required to startup the cd/dvd drive. Feel free to write me back because the more I know about it (such as what you've recently installed or done to the computer), the more I can help you. Go to start, systems, and then control panel. Go into devices and look for your cdrom drive. Do you see it there? If you do, does it have a yellow exclamation point by it? In either case, go to Hp's website and go into the support site. You will be asked to type in your exact model of computer. There will be a list of drivers that you can download. Download anything that has to do with the cdrom. Install this/these driver(s), and restart your computer. It's really hard to fix computers from two sentences especially over the net or phone. =) Problems could be from anywhere like software related or hardware. I used to do this stuff for a living and this was the most common problem that people had. Hope this helped.
Jan 18, 2011 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
Everytime i open the computer it reads the feature you are trying to use is on a cd rom or removable disk insert the aiosotwarenpidisk
"AIOsoftwareNPI" is included on the CD that came with your HP All In One printer. Place the HP All In One disk into the optical drive (CD / DVD ROM drive) and restart the computer. "AIOsoftwareNPI" will automatically be installed after boot.
If unable to locate the ****, go to HP's website to download the disk for your particular All In One printer.
I hope this helps. Please rate my reply - thanks!
Jan 03, 2011 | Microsoft Windows XP Professional for PC
I have a hp pavilion a562n computer and im looking to replace my dvd drive. Can you give me a detailed guide on how to do this???
Go to this link
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=408385&
Its to the manuals of that computer. Select PART REPLACEMENT INSTRUCTIONS. Download the file. The file is a pdf file that shows you how to remove it and install it.
hope that helps
Oct 26, 2010 | HP Computers & Internet
How do I open the tower to insert a c d
Open My Computer and then right click on the CD/DVD drive of your system that are define. For example: "E, or F, or G". Click on eject. or Press on the button CD/DVD-ROM. Mostly it's located in the right sight just below the CD/DVD-ROM "where the CD/DVD can insert". And if this two is not working than take a pin length around 2.5" and push inside the hole it's located in the right sight just below the CD/DVD-ROM. Hope it'll be helpful to you. All the Best!
Oct 07, 2010 | E-Machines eMachines Desktop PC
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
DVD DRIVE OF MY HP LAPTOP
Hi there:
If you know how to boot the computer into bios look for the boot section and check to see if the cd rom is there if not change the settings to show a cd rom and than save and reboot but i think you may have damaged the cd rom when you forced it open these are pretty delicate devices , force should never be used .
best regards mike
Feb 16, 2009 | Toshiba Satellite U305-S2804 Laptop
Driver problem
What device driver are you looking for?
The driver for your Wireless card is available from HP at: http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=3554086&lang=en
If thats not the one your looking for, let us know so we can track it down for you.
Jan 09, 2008 | Computers & Internet
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
Cd-rom/dvd-rom door won't open
Hi!This is not a big problem...All you have do is take a pin, needle or something and just insert it into the small hole near your cd-rom drive..try this repeatedly while pressing the eject button..If it doesn't work you will have to unscrew the two screws on the right of your keyboard..doing this will give you the access to the cd tray and you can remove the cd and put it back together..
Nov 13, 2007 | Averatec 3200 Notebook
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
110 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
