Question about Kenmore Dryers
What type of screws do I need for a Kenmore 80 series dryer power cord (where the three screws hold the wire to the terminal)
I got a used Kenmore 80 series dryer, and the previous owner kept the power cord and the three screws that hold it in. I bought a new cord, but don't know what size or type of screws are need to hold it down (the 3 wire screws; not the larger ones on the side).
    Master:
  • Kenmore Master
  • 610 Answers
They are machine screws. Remove the terminal block and take it to the hardware store to match the size of the "lugs." Terminal Block 5304409888
Posted on Oct 19, 2016
Started drying load, dryer shut off. won't turn on. checked door, changed thermal fuse, checked breaker. still doesn't work. light also not on.
If this is an electric dryer, you may have lost half of the power supply to it. Unplug and remove the little cover plate above where the power cord enters the dryer. Look at the 3 screws holding on the power cord for burned/black looking or loose connections. If nothing wrong there, shut off house breaker and remove cover on house plug where you plug the dryer into and look for same type of issues.
Mar 17, 2015 | Kenmore series 70 80 90 Dryer Motor...
Kenmore 700 dryer with a three prong cord is being converted to four prong. Is there a drawing of what wires by color going to the proper screw location?
There's a ground strap wire (green/yellow) attached to the dryer cabinet and connected to the center terminal where the white neutral wire of the power cord is connected. Disconnect this ground strap wire and remove the 3-prong power cord from the terminal block taking note where the wires are connecedt to. Connect the 4-prong power cord in the same way same wire colors of the 3-prong cord are connected to the terminal block. Connect the ground strap wire to the remaining fourth wire (green/yellow). Just do the reverse when converting 4-prong to 3-prong. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 13, 2011 | Kenmore 700 6972 Dryer
Need to replace 4 prong cord with a 3 prong cord on a new 500 series dryer.
On the back of the dryer, remove the screw(s) that hold the access cover to the back panel that cover the terminal block where the cord goes through the back panel and connects to the wiring terminal power block, loosen the two screws on the cord clamp the clamp it to the back of the dryer just enough to release the cord, remove the four nuts / screws that are connecting the 4 wires from the cord to the terminal block and or the back of the dryer,with the new 3 wire cord just match the colors on the terminal block with the same color wires that are connected to the other side of the terminal block, red,black on the outer most terminals and the white or green to the middle terminal, IT IS IMPORTANT THAT YOU PLACE A JUMPER WIRE/STRAP FROM THE MIDDLE TERMINAL WHERE THE WHITE OR GREEN WIRE CONNECTS TO THE TERMINAL BLOCK OVER TO THE CASE/CABINET OF THE DRYER, THIS CAN CONNECT TO THE CASE AT ANY AVAILABLE SCREW NEAR THE TERMINAL BLOCK! In short this means that the neutral and ground of the dryer must be connected together in a 3 wire set-up.
GOOD LUCK!
Aug 21, 2010 | Kenmore 500 6952 Dryer
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
I NEED HELP CHANGING CORD TO A 4 PRONG ASAP!!THANKS
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Comments: Jul 23, 2009- bf71290.jpgfb4d3ed.jpg
Three wire Four wire.
Better? Best wishes and sorry about the pics. Hope this is better.
Aug 17, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Need to replace the power cord
This is actually one of the easiest repairs to make on most dryers.
Unplug the dryer from the wall of course.
At the point where the dryer cord enters the dryer itself there is usually a plate. One screw should hold this plate in place. Remove the screw and pull the plate out (it should only be held in by a couple of tabs). The cord is attached to the power supply with three (or four) terminals. Back the screws out and slide the cord out. Make careful note as to which color goes to which terminal. Usually the black (or red) color goes to the gold screw and the white goes to the silver screw. The green screw holds the ground wire in place which is also usually a green cord.
Once you have done this step then loosen the screws that hold the cord in place on the plate. This fitting should open as you loosen the screws and the cord should pull out easily. Then thread the new cord through the fitting and reverse the process. Just remember to thread the cord through BEFORE you connect the wires so that you don't have to undo your work!
Hope this helps!
May 25, 2009 | Whirlpool Dryers
Kenmore 400 series electric dryer
  1. Remove safety plate (usually attached only by 1 or 2 screws)
  2. Remove old cord and restraint with a hand or cordless drill.
  3. The restraint is the collar that fits tightly around the cord to hold it firm to the dryer.
  4. Connect the center wire of the 10/3 cord to the center silver terminal. Turn screw in firmly but not too tight.
  5. Now you have two wires remaining which are attached on either of the two terminals beside the silver terminal. It does not matter which wire goes on which terminal, as both wires are hot. Screw in firmly.
  6. From the outside of the dryer, you need to slide the tab end of one of the collar halves into the 10/3 cord wire hole. Do the same with the other half of the collar,easily draw the two halves together to tighten against the cord .
This is the 4 wire view 43fa7d5.jpg This is the 3 wire view
Please rate this a fixya
Feb 08, 2009 | Kenmore 73952 Gas Dryer
Correctyly wiring power supply to Kenmore dryer
A three wire pigtail is connected thusly. The two outer wires go to the two outer terminals on the dryer, the center lead goes to the center of the dryer terminal block. If its a four wire pigtail, the outer leads go to the two outer terminals on the dryer, the white goes to the center terminal. The jumper strap on the center is removed and the green goes to chassis ground.
Sep 16, 2007 | Maytag Neptune MDE7500AY Electric Dryer
Dryers Logo
319 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
