2001 Daewoo Nubira Logo
r
rene Posted on Oct 13, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My windows dont work anymore when i push the buttons it just locks the doors have no idea how to fix
Windows dont roll down anymore
Bogdan Odwazny
Level 3:
  • Daewoo Master 6,171 Answers
  • Posted on Oct 14, 2016
Bogdan Odwazny
Daewoo Master
Level 3:
Answers
6171
Questions
8
Helped
1201398
Points
19890
Did you check fuses?
Testimonial: "yes sir, all are good!"
  • 3 more comments
  • rene
    rene Oct 15, 2016
    yes all are good
  • Bogdan Odwazny
    Bogdan Odwazny Oct 16, 2016
    All windows not working,did you try new fuses?
  • rene
    rene Oct 16, 2016
    Yes all four just makes locks go up and down in main switch and the other doors nothing and I should change fuses even though they look good?
  • Bogdan Odwazny
    Try to move wires driver side door and push buttons.between door and post.
  • rene
    rene Oct 16, 2016
    Ok thank you I will try first thing in mourning
2002 A4 window lock button stuck
hi maby try some silicone lubricant spray on the switch and try working it up and down for a while if that doesnt work you will need a new switch
1helpful
How to open the door on a 2004 altima if both of my handles dont work
There are f few ways. Bust the plastic handle off the outside . Make sure the door is not locked. If you can get inside the door this way and see a rod near the door handle. Push up and down [ usually down ] on this, door should open . OR Roll the window down. Pry up on the inner door panel by the rubber piece that clears your window. This piece should be able to pry up, enough to see the same rod I am talking about.Usually, these rods push down to open the door. #3 Roll up window, put a small wedge between the window and the door by the door handle. This should get the gap open enough to look down inside the door. Look for this same rod, near the door handle, and push down on it to open the door. replace Hope I was helpful please rate this solution
Wife locked her keys in the car. Removed the water guard and pried on the door so I could fit a coat hanger inside the car and tug on the power door lock on the inside of the cab. After unlocking the...
replace the motor, the mecanism is made of plastic inside and it has too much freeplay so it ends jammed crooked in the casing, common problem with electric windows
Driver`s window works, all the other windows do not .
My Cherokee has a window lock button on the driver door (A child safety feature). See if your is locked... push the button and try your windows.
Hope this helps... Good luck!
2helpful
2answers
94 T-Bird - Passenger side window
can you see the window assembly.. you should be able to see the gears for the window crank as it sounds like the gears are stripping... You should be able to get to the bolts that are holding the window assembly to the door.
2004 ford mustang
this may sound stupid but its only a temporary fix. take the panel off the door and tap the window motor with a small hammer. do all the other windows work? does it make any sound when you hit the button? you probably end up having to replace the window motor.
Top Daewoo Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Daewoo Expert? Answer questions, earn points and help others
