Question about Hampton Bay 52 In. Ceiling Fan, San Tropez
Does anyone know if I can make this a regular fan without the 14 in rod
    President:
  • 1,273 Answers
You can replace the downrod with any other length. Not a problem. Just make sure that you get the same diameter. Have done it several times.
Regards. --W/D--
Posted on Jul 19, 2009
Thermal protection
The thermo protection is located under the shrink wrap where the blue power wire comes into connection with the motor field winding and the cap feed. The continuity between the plug end and the blue wire at the Capacitor will be broken.
Jun 02, 2013 | Lakewood HV-14/C Fan
Wiring a single phase 14 in fan
please do not rate this as an answer, just wanted to see if you have a model number of the fan, motor, speed controller, etc. many people here can help you, but providing an answer without knowing exactly how the default wiring is set up is never a good idea.
Nov 20, 2007 | Dryers
I have a mpi 2400 monitor. I ran low on fuel so I went and got 4 or 5 gallons to keep it going till my delivery came, but it keeps shutting of and getting an error E 14. I know this means there are...
usually when you run out of oil,you need to bleed off air. there's a bleeder on pump looks like bleeder on a car brake cylinder.atach a piece of rubber hose and run to a bottle, open it up when pump is running till all you get is oil.
Jan 25, 2011 | Heating & Cooling
Can i replace a tie rod {inner} on a 94 ford mustang , drivers side without taking off rack and pinion. I need to get a roll pin off the inner tie rod and thats the problem it looks pressed in not set...
Real simple, assuming you know how to take the outer tie rods off. You have to take the clip that holds the plastic boot on off, then slide back the plastic boot, and you'll be able to unscrew the whole inner tie rod assembly. The hardest part of the whole process is installing the new ones to the exact settings of the old ones
Mar 13, 2010 | 1994 Ford Mustang
Please help. I'm trying to take the two fan
There should be a simple retaining clip at the outside of each of those fans(much like the ones that go around small hoses). Take off those clips and slide the plastic fan off the rod. Of course, sometimes such things are not as easy as they sound. If the rod shows rust or grime, you may have to hold the rod with a pair of pliers (in the portion that the fan will not slide over) and turn the plastic fan a few times to break if loose from the rod, then work is slowly off. Some steel wool on the rod before you replace the fan blades might make it easier to put new ones on.
Hope this helps you.
Oct 30, 2009 | 1992 Honda Accord
Light or fan will come on with without remote
Most remotes use an X10 format that transmits over wires .. Odds are someone else in your neighborhood is on the same code. Does the light come on with regularity? If it does than that is your problem. Without knowing the exact model I can't tell you how to change the code. When you change it you must change the receiver and the transmitter
Oct 02, 2009 | Heritage 30" Children's Room Ceiling Fan...
Looking for a small 14" rough in...
not sure of over all lenght but a 14" rough is what we use to get at any real plumbing supply house
Aug 17, 2009 | Crane Plumbing Toilet To Go Tall...
Noisy fan
Ebay is a good source to get parts for Toshiba satellite. Look at Toshiba satellite for parts. Ton of them on regular basic.
Jun 04, 2009 | Toshiba Satellite A15-S129 Notebook
91 Ford Raner 2.5 2wd Shift Lever Assembly
At the bottom of the shift lever there is a threaded rod with a nut on the front-side of it. Unscrew that nut and then thread it onto the rear-side of the rod. When you tighten the nut on the opposite side, it will act as a puller and get the shaft out for you.
Dec 27, 2008 | 2001 Ford Ranger Regular Cab
Need torque specs
Torque sequence:
Step 1: Torque 29 to 34 Ft/Lbs
Step 2: Torque an additional 90 to 120 degrees
Oct 14, 2008 | 1997 Ford F150 Regular Cab
Hampton Bay 52 In. Ceiling Fan, San Tropez Logo
83 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
