Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Vertical lines of intrference.slowly schrolling up..what up wit that?
    President:
  • 563 Answers
If it's just interference, it's being caused by something electrical in the home. If you have actual lines that never go away no matter what, that sounds like a repair issue. Call Panasonic customer service, and they will advise you to try a few troubleshooting ideas.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 19, 2009
  • 250 Answers
The problem may be due to 60hz (cps) power line interference making its way into the TV either through the cables that are connected to the TV or through the AC power wire. A good test is to unhook everything and connect a VCR to the TV and play a movie to see how the TV screen looks. If the TV screen doesn't show the lines when playing a movie, the problem is coming into the TV from one of the cables. Try hooking up one item at a time until the noise bars show up, when they do that cable or device is the cause of the noise bars.
Dark horizontal line traveling across the screen vertically
on tube tvs bestto go on main bord look for hairline craks on soldering ok redo them nice it will light up happend to mine also older model thx nick
Feb 06, 2008 | Sony FD Trinitron KD-34XBR960 34" TV
AOC vertical white line moving across the screen
I have dual AOC i2553ph monitors. One day I came into work and notice one of them had a single vertical white line moving slowly back and forth across the screen that looked like a scan or radar function. I reset the monitor from the OSD and all is well again. Use "Extra > reset" from the OSD on AOC monitors.
Jan 31, 2012 | AOC Computers & Internet
Blue vertical and hrizontal lines moving slowly
This is usually caused by a ground differential. on the cable box. Solution is to put an F-type cable box ground eliminator on the incoming coaxial cable line. You can test this theory by unplugging the Coax on the INPUT of your cable box. They are less than $12.00. For more info go to www.cedia.org and put in your zip code to find the closest in home tech to install one for you.
Feb 10, 2010 | Ronin P807 DVD Player
Philips TV (old) showing a horizontal line in center of screen
Check for the cracked solder joints on the IC or dried capacitors on the vertical side
Mar 28, 2009 | Televison & Video
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
Jumpy / Schrolling Picture...?
this is a problem of synchronization.  are there any adjusting knobs in the tv set (vertical hold adjust) if  yes you can try but if none maybe consult a technician.
Oct 30, 2007 | Akai PT5492S 54" Rear Projection...
No picture
a bright thin line in centre is called horizontal line. first of all do not keep tv on unless it is rectified. BUT If you want to put on tv keep brightness minimum to protect your screen for any demage. now solution your problem is in vertical section. 1 check vertical supply. 2 check parts in vertical section or loose contact. 3 yoke connrctor loose 4 ic defective It is not serious problem can be rectified easily
Sep 19, 2007 | Toshiba 32DF46 32" TV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
149 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
