Installed module. Now: Codes--B0014, B0018, B0026, B0043, B1001. Dealer won't touch.
You can't just replace parts like that .
DTC B1001 Option Configuration Error
When the ignition is turned ON, the inflatable restraint sensing and diagnostic module (SDM) compares the restraints ID that is stored in the SDM to the restraints ID that is stored in the body control module (BCM). The restraints ID that is being compared contains the last four digits of the SDM part number. Then, the SDM compares the VIN that is stored in the SDM to the VIN that is stored in the BCM. For more detailed information concerning the class 2 data lines, refer to Data Link Communications Description and Operation in Computer/Integrating Systems.
If the SDM is replaced you must setup the new SDM part number in the BCM. With a scan tool, select the SIR module setup. Select Setup SDM Part Number in BCM and follow the on-screen instructions. After, you must setup the new SDM. Select Setup New SDM and follow the on-screen instructions.
Wow! Just an awesome answer to a question that I have asked everybody I could find--thanks so very much Jeff. When I first got the replacement module, I sent it to a module reset company in Miami with my current car's VIN as well as the IDs on all of the component parts I could locate for them to enter that information. Let me give your directions a try and see how it works out. Thanks again. Paul Meyers, Baltimore, MD.
2001 Chev Impala LS
