Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Water won't dump
I have an older Whirlpool Thin Twin stackable washer/dryer. I just finished replacing the "water pump" because water was leaking at the front of the machine near the bottom. The replacement pump worked great ... ... the leak stopped. The problem has now changed to something else. The washer filled with water and proceed to agitate. When it came time for the water to dump, the washer stopped. The dial proceeded through the cycle until it it "Stop", but the water stayed in the drum. The lid was closed during the process as to depress the Lid Switch.
  • 234 Answers
When you replace the pump, always to remember to makes sure the pump is pushed all the way in so that the shaft has a good grip. Try taking it out and pushing it all the way in. The 4 legs should touch the motor, as you put the 2 little clamps on the top and bottom.
Good luck, I'm pretty sure it's something really basic with the pump :)
Posted on Jul 19, 2009
Why doesn't my whirlpool thin twin fill up with enough water to was a large load?
No cannot over ride set at large doe the machine fill to a certain level then stop if so operating correctly if it never stops filling with water then there is a leak in the fill system either a hole in pressure switch hose it popped off tub or water leaking out thru drain system pump or siphoning thru hose again if unit starts to agitate there is enough water in unit per design
Aug 21, 2014 | Whirlpool Thin Twin Washer and Electric...
Overflowing Washing Machine, water does not stop filling, overflows to floor. This is a Whirlpool Thin Twin Stackable
sounds like you have a bad water level pressure switch part 3362987
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-LTE5243DQ6/1198/0152000/W0604125/00001?blt=06&prst=&shdMod=
go her part number 10 in diagram or there could be something in the hose,the hose could have fallen off or could have a hole in it,i can't find a video with a stack machine but this explains your problem
http://www.youtube.com/watch?v=jzKBUI5D0Vs
Mar 30, 2013 | Whirlpool LTE5243DQ Combination...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
Water leaking from stacker unit
No parts are replaceable within the pump. Buy a new pump.
Jun 22, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Twin Thin - Water Leak
It sounds like you have a bad pump. If the bottom of the washer is not solid just lean it back and take the pump off. There should be a streak of water stains on the inside of the pump if it is bad.
Nov 17, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
303 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
