Question about Hobart Champion 4500 Ac Generator/Ac Welder #500491
Full of oil was running and quit i started it up on first pull welded for a few minutes then quit again now it will not start. getting fire to plug and gas to carb. i cannot figure it out, any help would be appreciated. thank, Mack
    President:
  • 3,433 Answers
Sounds like a fuel filter or pump Mack
Posted on Jul 19, 2009
Miller Legend welder. Onan engine starts and runs a few minutes then dies. Why won't it restart for 5 minutes?
Some engines have a low oil cutoff switch. If the oil level drops to a certain point it kills the engine. Your oil level may be close enough that after starting and running for a little bit the level drops enough to kill the motor. After sitting for awhile the level rises enough to allow the engine to run again check the level and add oil if necessary.
Hope this helps.
Bob
Oct 22, 2015 | Onan Starter for twin cylinder engine...
Engin runs fine for about twenty minutes then quits. oil level is full
try and run it with a loose gas cap the vent could be clogged then check for spark when the engine dies or even better get a inline spark tester then you can see it when its dieing
Jul 12, 2012 | Garden
I just got a 1994 yz 125 and when i was riding it ,.. it would run good as long as i was going slow and not raping out the gears .. but when i would give it a lot of gas to take off it would bog out and...
if the plug is sooty your float is set wrong the air filter should have oil on it to catch dirt.sounds like a carb problem although it could be the power valve
Aug 24, 2011 | 2003 Yamaha YZ 125
Oil on sparkplug. cleaned plug but engine dies with oil on plug. gasket problem??
Oil on the plug is an oil problem. it means that either you tipped the mower and oil ran into the cylinder, or you put too much oil in it and it's leaking into the cylinder. Check the engine oil level, empty some if it's over the level it's supposed to be. You'll want to clean the cylinder, and here's how to do it. Get a can of starting fluid. Take the spark plug out, and remove it from the wire, spray a good 5 second shot of fluid in the cylinder, and pull the rope several hard pulls. This will shoot the fluid and oil out the spark plug hole, and the starting fluid will evaporate within a couple of minutes. Spray the firing end of the plug with starting fluid to clean, shake it out, blow on it to get the extra out, and let it dry(should take about a minute.) Pull the rope another round, and then put it back together. It should run fine after that. It'll probably smoke a decent amount at first, but it will go away within a few minutes.
Mar 27, 2010 | Garden
It won't start.
Prime away... on a chainsaw it does NOT squirt fuel into carb. It draws fuel from tank, through carb, and returns it to tank.
Using the choke however will flood it in a second once it has fired. with a good fuel supply, 99.5 % of chainsaw won't start problems are flooded. Lou
Nov 15, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Husky 2600 psi Powerwasher will not start, it was only used once, in 2008. gas was left in the powerwasher over last winter. I followed the 13 steps on hooking it correctly and turning it on etc.. when I...
You may have to take out the carb and get it cleaned / air-blown out. Looks like some little valve is stuck. Also make sure you are getting enough sparks at the plug tip. If you have left it long in a damp place it may take several pulls on the cord for the engine to fire-up and run. Try spraying some WD-40 into the cylinder through the plug-hole. Then pull the cord again. After a few pulls remove the plug again, and put like a spoonful of clean 10/30W engine oil into the cylinder, and keep pulling the cord until you see some smokes at the exhaust. If the engine fires up and run a few minutes, but stops later. The engine might be out due to incorrect oil/fuel misture.
Oct 20, 2009 | Garden
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Honda em2500 starts, runs 1 minute, quits and will not restart
If the oil level is low it will do this, but I also know this to happen when the oil is very cold (thick) an won't fow back own o the crankcase where the oil sensor is. The slow return results in a low oil level. My solution is to start it, when it dies wait a couple of minutes and retry... after a few starts, the oil will warm up, thus flowing back down faster and it then will run. Another option is to use a thinner oil ie;5-30w.
Apr 19, 2009 | Electrical Supplies
Hobart Champion 4500 Ac Generator/Ac Welder #500491 Logo
195 people viewed this question
Top Hobart Electrical Supplies Experts
Tim Venetis
Trevor Turner
Bill Boyd
Are you a Hobart Electrical Supply Expert? Answer questions, earn points and help others
