Question about Kenmore 47732 / 47734 / 47739 Electric Double Oven
911.48485890 Kenmore Double oven
This is the 2nd time for this problem. The top oven works fine but the bottom oven starts at 100 degrees and does not heat up. The last time I replaced both limit switchs that the manual shows in the control section and body section and still nothing. Finally I called a repairman. He replaced both switches and under his comments stated "installed vent duct limit switch and reset". Can you help with the location of that switch so I can reset it? This happens when we clean the oven. He also stated he advised the customer but he failed and I failed to asked where this bloody switch is to rest.
Arlington, WA
  • Don Middleton Oct 18, 2008
    top oven works fine bottom oven will not heat.
  • douglasfinn Dec 24, 2008
    We turned on the to oven to clean and now the oven will not heat up past 300 degrees. The convection fan blows all the time if you try to cook aboce 300 degrees. I have tried to let it heat up for 45 minutes and it just can not get there. Sounds like the vent duct limit switch needs to be reset, but I don't know where it is.
GE JKP26Gop2bg
If the oven is 23 years old, it could be time to replace it.
May 20, 2017 | GE Ovens
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Sep 20, 2015 | Thermador PODC302 30" Double Electric Wall...
I have a Fisher & Paykel double wall oven that I purchased in 2005. The top oven which was used most often stopped heating up to temperature in normal time. What used to take 5 minutes to get up to 250...
Google searches report that after running the self cleaning cycle this can happen. I am experiencing this issue with my Fisher&Paykel AeroTech Double OD302 but with the BOTTOM oven. I'm concerned as Thanksgiving is coming up and I need this baby working!
Nov 08, 2010 | Fisher and Paykel AeroTech Double OD302...
My bottom oven ( non-confection) will not go on-it will just sat 100 degrees but won't get warm or hot. Top seems to be working fine. This started after I tried to use the self cleaning feature.
If broil and bake do not work on your bottom oven, it is probably your lower thermistor or control board. If the bake works but broil doesn't or broil works and bake doesn't, it is very likely your heating element. With an ohmmeter, the heating elements should be about 40 ohms. Much higher or lower signals a problem. If you suspect the control board is the problem, they can be repaired quickly and reliably at
Oct 11, 2010 | GE Profile JTP56 Electric Double Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Nov 14, 2007 | GE JKP45 Electric Double Oven
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Kenmore 47732 / 47734 / 47739 Electric Double Oven Logo
73 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
