Question about Frigidaire Affinity ATF7000ES Front Load Washer
Cant get rubber boot back on - Frigidaire Affinity ATF7000ES Front Load Washer
  • 3 Answers
Vise grips to hold the green clamps. You need six arms and a lot of patience.
Posted on Jul 31, 2009
Where are the spark plugs located in kia sorento 2004
You will see rubber leads going to four or six spot depending on how many cylinders you have. Those are your plug wires which will lead to a rubber boot on the top side of your engine. Pull on the boot and it will expose the plug.
Jul 26, 2014 | 2004 Kia Sorento
The rubber between door and washing barrel has come out having bad time to put back in whats the trick to it thanks
One of these videos should help:
http://www.youtube.com/results?search_query=front+loader+boot+replacement&oq=front+loader+boot+replacement&gs_l=youtube.3...4396.15897.0.16459.29.29.0.0.0.0.314.4978.4j15j8j2.29.0...0.0...1ac.1.i4y90voxWoA
Jan 28, 2013 | Washing Machines
Best way to change plug wires
the best way to change plug wires is one at a time this way you cant mess up the firing order if your having trouble with stuck wires you can try twisting and pulling the rubber boot and to keep that from happing again get a tube of dielectric grease and put a little on the inside of the rubber boot before installing.
Jan 14, 2011 | 1996 Chevrolet Caprice Classic
Leaking water from the front
The problem is due to the rubber boot is been torn that is causing you the leak. You have to check the rubber boot for leaks by removing the clamp assembly that secures the rubber boot to the outer lip of the door opening. Peel off the rubber boot then inspect it for any holes where it may be leaking. The rubber boot in your washer can be accessed only when you remove the front panel. This requires the removal first of the top panel then the console. Also check your inlet hoses on the outside of machine, also check the connections inside the panel in back.
Thank you !!
Jul 06, 2010 | LG WM-2277HW Front Load Washer
Leaking water from my lg front loader during washing cycle- wm2487hrm
Thank you !!
Jun 13, 2010 | LG WM-2277HW Front Load Washer
Cleaning rubber door boot
I am not sure how the Whirlpool rubber boot is constructed but the Maytag's can be pulled back enough to get a sponge, washcloth, etc. around it to clean it. If you can get to it try a product like odorban which will clear up any mold, mildew & icky smells without harming the rubber itself.
Mar 03, 2010 | Whirlpool Washing Machines
My drivers side door stopped working electrically. the keyless entry works but the none of the buttons work, windows door or locks but the window lock out works 1999 jeep grand cherokee
if you open the drivers door and look for the rubber boot near the hinge, pull the boot back and you will find a heavy blown wire with (i think with a red trace) will be broken. join the wire together and solder so it cant pull apart..
Jan 22, 2010 | 1999 Jeep Grand Cherokee
Bought a replacement driver side mirror, cant find where to unplug the old one.
Is there a mirror control toggle on the inside of the automobile?
If there is, and it has a rubber boot, you should be able to remove the rubber boot and find screws to release the mirror.
If there is no toggle switch, perhaps the mirror assembly snaps off. Yo might ask the dealer as well.
Oct 07, 2009 | Dodge Caravan Cars & Trucks
Homelite 330 has no spark
Hi
First check if the plug wires is conected with the terminal from the rubber boot,pull the terminal out of the boot,crimp it with pliers and slide it back into the boot(has to fit snugly on the plug.Let me know
please.
regards savumihai71
Dec 10, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
BIG RUBBER BOOT PULLED AWAY BY TUMBLED CLOTHES
you will need a new boot and the two clamps. get back to me when you have the parts and i'l tell you how to do the job
Nov 20, 2008 | Washing Machines
Washing Machines Logo
77 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
