Im having problems with my a/c blower going out, you can hear the a/c click on but no air comes out of the vents. i replaced the fuse for the blower and that worked for about a month and than went out again.
    President:
  • 3,433 Answers
Ck the blower. The squirel cages may be loose on the motor shaft and simply need to be tightend.
Posted on Jul 19, 2009
There is no cold air or hot air coming out of vents. just stopped one day
You can hear what ? Blower motor ? Probably the blend door actuator is not working . I 'm questing because I don't know what make vehicle you have .
Nov 08, 2015 | Cars & Trucks
Heat or A/C does not work in my car?
Either you have a blower motor FUSE that has gone bad "typically the problem" or you have a burned out blower motor. Usually the cause of a blown or burnt motor if not a Fuse, Is caused by the vented air from outside letting debris like sticks or leaves,acorns etc. enter the fan box. If ANY of the mentioned items get caught in the "blower box" then it will usually blow the fuse and or burn up the blower motor. Start in your fuse box and look for a burnt fuse and replace with same size fuse. If it blows the new fuse quickly then you have debris in "Blower box" that will have to be removed before adding yet another fuse. I have had the same problem and I found a bunch of leaves in my "Blower Box". I removed the leaves and replaced the burned out fuse. And I have had no more problems with the blower motor blowing air.
Nov 09, 2013 | 2004 Ford Taurus
Pontiac g6 2006 heater/ac fan doesnt work on #3 speed setting, fan made squealing bearing noise for a while but quit, also inside/outsied air vent switch vent makes clicking noise when set to outside air
you will need to replace the blower motor as it has probably siezed going by the squealing noise you say you heard.i`m assuming this has more than 3 speeds for the fan motor.if it wasn`t working on one speed then you probably have a bad blower motor resistor that will need to be replaced as well so you will have all fan speeds.this is located in the air duct housing near the blower motor and will have about 6 wires on it.some of these on under the hood on the firewall anywhere from the passenger side to the center of the firewall.not sure about the vent switch.if the vent switch is moving the doors and you hear a clicking then you may have a vent door problem that the door pivot is worn.
Nov 01, 2013 | 2006 Pontiac G6
Circuit unit behind the ac controls
sounds like your blower motor has stopped working check for power going to the blower system if you have power the blower is probably bad the concern is the lack of a fuse blowing or a breaker not cycling you may have a harness problem sometimes a low grade short will heat up wires then melt them together causing a multisystem failure even though a fuse or breaker didn't blow check you harness
Aug 09, 2012 | Dodge Avenger Cars & Trucks
1995 gmc sierra heater control prob
Im having a similar problem, sometimes my blower works other days it wont will when it does work no hot air comes out, blower controls change but no hot air, i replaced the thermostat and now my blowers are not working!
Nov 21, 2011 | 2002 GMC Yukon XL
A/C blower has stopped. Still has cool air coming out of the vents when I accelerate. What should I check for first? Sometimes I hear a sound that might be from the vaccum.
CHECK HVAC FUSE OR BLOWER MOTOR RELAY/FUSE.IF BOTH GOOD BLOWER MOTOR BAD OR CONTROL SWITCH GOING BAD.IF YOU HAVE TO REMOVE BLOWER MOTOR HOTWIRE TEST IT BEFORE BUYING ANOTHER ONE.BE SURE TO DISARM AIR BAGS SYSTEM WHEN WORKING AROUND DASH OR STEERING AREA.REMOVE AIR BAG FUSES TO DISARM.WAIT 10 MINUTES.WHEN YOU GET READY TO ARM AIR BAG PLACE FUSE IN.TURN ON IGNITION THE AIR BAG LIGHT WILL FLASH 7 TIMES THEN TURN OFF.
Aug 08, 2010 | 2004 Chevrolet Silverado
I have no air coming out the front vents of a 2003 suburban the fuses looked fine. What else could there be and if it is a blower, how do you replace it?
Does air flow from any locations? Can you hear the fan running? The blower is above where the passengers right foot would be. It is removed from the inside the car.
Feb 05, 2010 | 2003 Chevrolet Suburban 1500
Blower not blowing
can you hear the fan working on all speeds?
Sep 22, 2008 | 2002 Jeep Grand Cherokee
No air coming through vents and blower is OK
your blower motor might be damaged.replace the blower motor of the air con.
Aug 20, 2008 | 1988 Volvo 740
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
