Question about Motorola Mobility RAZR V3
Phone won't charge?
When i plug in the phone it does nothing, no charge indication nothing,so i cleaned all the connecting points including the plug end and still can not get it to charge? Even changed batteries and still nothing could use some tech support on this little jewel please?
  • 4,102 Answers
Have you tried a different charger as the wies in the charger often split causing it not to charge if you have replaced the charger and still dont work then the board on the phone could be warped or the solder could have come off on the charge points inside the phone i dont advise taking the phone apart yourself as this could dammage the phone further as it needs to be undone in certain order and the same back together and also the screws need to be torqued up to a certain setting else the board can get warped and render the phone useless hpoe this is some help
Posted on Nov 19, 2007
Why does the battery drain while charging?
Could be a loose plug (on the inside of the cord or the phone, not that the plug is not in all the way). Keep a close eye on the battery/charging indicator on the phone, grab the plug (like you're going to pull it out), and slowly press it up, down, and sideways. If the charging indicator turns off and back on, you have a loose plug. First try a different cord. If it does it with more than one cord, it's a problem inside the phone. There is nothing you personally can do to fix it at that point, you will have to bring it in to a Sprint store for repairs.
Aug 03, 2015 | LG Nexus 5 White for Sprint CePhone
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage( Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
Phone won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 28, 2012 | Pantech Pursuit Cell Phone
My motorola Blur won't charge, I've tried other chargers and nothing, it will catch a charge for a second and then nothing, now my phone is dead
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
Sep 15, 2011 | Motorola Mobility CLIQ Cell Phone
Sony Ericsson G502 mobile when charging ,its indicator on back side works but the whole mobile is not working, but when i connect the points of its charger with the points where battery connects, its...
sony ericsson W868 mobile, when i plug the cable in USB for charging, its not working. there are no other area for charge. how to charge this mobile.
Nov 13, 2010 | Sony Ericsson Cell Phones
No display to indicate battery is charging Nokia E63
to confirm that the phone is charging, switch on the mobile and charge or turn on the mobile when it is charging.if it doesn't works then try with some other charger,still same there is some problem with the battery r the connection point.check with the vendor.they will definitely assist u.
Aug 19, 2009 | Nokia Cell Phones
No indication of charging after connecting to usb
Try the followings:
1. Plug the phone back to the pc and see if it will charge it. Or if it would beep when a cable is plugged to it. If I'm not mistaken, the driver for your phone should charge it when plugged to pc.
2. If nothing happened from doing the above advice, then get a toothbrush, dip it rubbing alcohol and brush both the phone's charging port and the charger itself.
Best of luck....
Jul 15, 2008 | Motorola Mobility RAZR V3i Cellular Phone
K1 Problem Charging Battery
sounds like the battery to me. there is a chance it is the phone. Check on your warranty and see about a battery replacement first. Its much more likely.
Jan 13, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
A good trick to ensure a good connection for a cordless phone to it's base is to clean the silver connection points with a pencil eraser.
Mar 29, 2007 | Panasonic KX TC1701 Cordless Phone
Motorola Mobility RAZR V3 Logo
55 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
