Question about Video Cameras
The silver wheel that reads the tape or spins the tape thru has come loose. I can not play back or record video.
  • j_staples_8 Jul 19, 2009
    I have had the camera for three years, so I dont think I have a warranty. I am cool with do it yourself projects. I just wish I could find info on removing the outter skin of the camera, so I can get to the wheel. I think I can remove tape deck cover and get to it that way, if so I won't have to take the cam completely apart.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
HI. Does not sound like a do-it-yourself project,and I'm not scared to tackle most htings. Warranty?
Posted on Jul 19, 2009
CT-W103 play back is to fast
You may have some broken tape wrapped around the capstan. The capstan is the small silver post that rotates when the tape is playing. A rubber roller presses the tape against the capstan. This silver post needs to be just that - silver. If it has any brown tape or goop on it, clean off the tape or goop with a small knife. Then follow up with nail polish remover [acetone]. Don't use alcohol because that will harden the rubber roller over time.
Feb 15, 2016 | Pioneer CT-W103 Single Cassette Deck
Hi, I have a sony tvr 140E. When I try to play back a tape that was recorded from another digital 8 camcorder I get blue screen. when I play back a tape recorded on my camcorder plays fine. Any...
This smacks of the same problem that the old VCR's used to have. One of you are out of sync. The tape records on a portion of the tape in a sort of straight line track. Think of it as your track is down 1/16" from the top. The other camera tracks it's video down 1/8" instead. That's why in playback it can't read it. The only cure is a realignment. Nimsgame
Feb 19, 2011 | Sony Handycam DCR-TRV460 Digital Camcorder
DCR-TRV530 Digital 8 . . . Problem started with tape being caught in heads. Got a 3121 error message afterward . That stopped but in video playback mode only blue screen with play arrow at top? In...
If video head got clogged then camcorder wont read tape in playback so result comes as blue screen.
Please use video head cleaning tape and clean video head of camcorder. This will solve your problem.
Video-8 head cleaning tape is available with amazon.com
Thanks.
Dec 03, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
Recording and Playback error
I'm not sure what the solution is, but I am having the same probelms, and I would appreciate any help with this since I am shooting a childrens camp and I am fairly isolated and don't have the time to swop cameras or send it to get fixed. I need to know if the recording is fine (video and audio) but the playback is not working correctly...or is it not recording correctly or playing back correctly. The sound cuts out from time to time in playback. Thank you.
Dec 09, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Audio muffled when playing back video tape
Have you tried using a wet type head cleaning tape? If not, run one thru at least 3 times.
Feb 05, 2009 | Sansui COM3101 13" TV/VCR
Canon uc-1 video 8mm camcorder
Yes it can be fixed, but Canon is not the easiest to work on. Is the connector loose at all? The audio head may be dirty. This is not on the spinning heads. If you look inside and locate the pinch roller (rubber roller), there should be a silver head that looks like a cassette tape head. Try cleaning that using a cotton swab and alcohol. See if that resolves the problem.
Keep us posted.
Dan
Jul 23, 2008 | RCA 8MM VIDEO HEAD CLEANER (WET) 8mm Tape
Blocks of noise
Don't know about the slow motion, but the noise is usually from dirty heads. Just like a cassette player it needs them cleaned periodically. Dip a Q-tip in rubbing alcohol and rub over the entire path the tape takes. You'll see a little block that actually reads the tape. Thats what you need to clean.
Make sure you eject the tape and remove the battery while the tape drive is open to clean it. Rubbing alcohol dries fast but give it an extra ten minutes and check it again.
Video recorder while the heads were dirty will not change however new video should be clean.
You may also have a bent tape carrier that is putting your video off track. It needs to be pushed or pulled to realign it.
It it's not the cause though, this can make playing back the earlier tapes more difficult since they will read and record in a slightly different part of the tape.
Jul 10, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
Picture and sound is skipping or stuttering during playback. It happens when playing any video.
This was often caused by mixing brands of tape. Do not use head cleaners more than absolutely necessary. More than half a dozen times or so, and heads are toast.
Use quality tapes of the same make/length, from new, and you will be fine. (the coatings on the tapes vary, and can/did interact with each other.)
Nov 02, 2007 | Sony Handycam DCR-TRV310 Digital Camcorder
Playback difficulties
Not specific enough but I would run a head cleaner thru it for 10 seconds and see if that improves things and always use the same brand of tape to prevent gum issues.
Jun 01, 2007 | Canon ZR60 Mini DV Digital Camcorder
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
