Question about HP Photosmart C7180 All-In-One InkJet Printer
HP C7180, "cannot print, please replace the empty cartridge(yellow) to print." The ink cartridge is NEW and everything looks good but doesn'twork. I've done every reset I can find but still no luck! plz help
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
REmove and replace the cartrideges again.
Posted on Jul 19, 2009
Hp Besiness inkjet 1100 fault codes cayan maginta ink and paper lights come on dead
HP Business Inkjet 1100 stops everytime after the first line stars to print. The power is one, the ink drop light is lit, the "yellow" indicator light also on, and the paper light all on. None of them blinking. We replaced the yellow cartridge with a brand new HP 11 yellow cartridge. Turned the printer off and on to reset. Printer comes on everything looks good till you try to print anything, even a on line word doc? Then it happens again, so we replaced the yellow again...same thing. We ever cleaned print heads, Any assistance would be welcomed?
Jan 12, 2010 | HP Business Inkjet 1100dtn Printer
Brand new yellow ink cartridges are always read as empty
We have a step by step solution posted on our we site at: www.ccl-la.com/HP.htm The problem is air in the ink lines and the guide helps you purge the air from the system and restore printing.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
Won't print after replacing cartridges
The following text copied from HP website to tackle this problem. minimtop.gif Follow the instructions below to install the print cartridges. NOTE: If you are installing ink cartridges in the unit for the first time, be sure to use only the print cartridges that came with the unit. The ink in these cartridges is specially formulated to mix with the ink in the print head assembly at first-time setup. s.gif Installing the print cartridges minimtop.gif
  1. Verify that the unit is on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00718797.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00721793.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
  4. Remove the new ink cartridge from its packaging.
  5. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot. NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted. Figure 3: Inserting an ink cartridge c00721795.gif
  6. Press down on the gray latch until it clicks into place. Figure 4: Closing the gray latch c00721796.gif
  7. Repeat steps 3 through 6 for each ink cartridge that needs to be replaced. NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  8. Close the ink cartridge door. Figure 5: Closing the ink cartridge door c00718798.gif
s.gif s.gifHave a Good Day
Jul 17, 2009 | HP Photosmart C4580 All-in-One InkJet...
HP C718 Yellow print cartridge showing cartridge empty or damaged. Tried two new HP cartridges, Cleaned printheads and exhausted HP online and telephone support without success. On inspection it looks as...
If one of the contact pins in the printer is damaged you will need to replace your printer. I don't think it is a problem with the cartridge because it is highly unlikely that you would get three HP cartridges in a row with damaged chips on the cartridges.
Jun 05, 2009 | HP Photosmart C7180 All-In-One InkJet...
Hp c7180 printer does not recognize new ink cartridge
be sure you removed tapes from cartridge.
Follow the instruction and reinstall new cart.
Feb 09, 2009 | HP Photosmart C7180 All-In-One InkJet...
Will not print cartridges out of date
I never heard of that for the C7180 all-in-one. Remove the ink cartridges. Dampen a rag with water. Slide the cartridges across the rag until you see ink. If yes, than good. Grab a couple of cotton swabs & drip a couple drops of alcohol onto a tip. Wipe the copper contacts off on the ink cartridges. Do the same to the contacts within the ink carriages. Replace the ink into the carriage.
From your computer, open Printer and Faxes. Make sure your HP C7180 all-in-one printer has a check mark next to it. If not, left click the C7180 once so its high-lighted. Than click "File" in the upper left corner of the window. Left click, "Set as Default printer". Than right click once on the C7180 & slide to & left click on Properties. In the next window click "Printing Preferences", Another window will open. Left click the "Services" tab. Click the "Service this device" button.
Than click, "Clean the Print Cartridges". When the printer finishes, click "Print a Test Page", button. (If you do not see ink on the test page than your ink cartridge are too clogged & you'll have no choice but to replace them).
Using the damp rag loosens possible clogged/dried up ink. Cleaning the contacts with alcohol removes oil from touching the copper contacts with your fingers, also removes dust. Always keep a cover over your printer when not in use. My current ink cartridges are at least 1+ year old. HP & other manufactures do use tracking software to monitor your ink cartridges in this fashion. If you remove an empty cartridge & re-fill it & replace the cartridge the software knows. Each cartridge has a tiny chip attached to it.
The internal software knows when you fill a ink cartridge & can shut down your ability to print. Forcing you to buy new ink cartridges. Below is the HP link for your C7180 printer.
http://search.hp.com/query.html?charset=iso-8859-1&lk=1&la=en&nh=10&rf=0&qs=&hpvc=sitewide&uf=1&st=1&qt=replacement+cmos+battery+for+HP+C7180+printer&submitsearch.x=2&submitsearch.y=4
Good luck timmer047!
Mike
Dec 17, 2008 | HP Photosmart C6180 All-In-One InkJet...
C7180 Print in color without all cartridges
You can usually print with an empty cartridge, even though the software will inform you that the cartridge is empty. Your print quality may be affected, however.
Dec 03, 2008 | HP Photosmart C7180 All-In-One InkJet...
Ink system failure
HP Photosmart C7180 will not accept new '02' yellow ink cartridge and repeatedly states 'printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume.' This is the 2nd HP '02'yellow I've bought and it continues to say the same.
Sep 06, 2008 | HP Photosmart C7180 All-In-One InkJet...
How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Dec 29, 2007 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C7180 All-In-One InkJet Printer Logo
553 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
