Question about Microsoft Xbox Console
Connectivity One controller port does not connect. The other three work fine. I have switched the controllers around, they all work fine form the other working ports.
  • 27 Answers
It sounds Like a bad port, You can try and replace the Ports first this would be the least expensive rout. After you have replace the Port and it's still not working you will need a new Motherboard.
This will Get you started:
Posted on Dec 03, 2007
TV box is not working wend Is connected to HDMI switch.
Jan 31, 2014 | AUVIO 4-In/1-Out HDMI Selector Switch with...
My son has a xbox360 and were trying to get xbox live to connect and it wont we had it working just fine on his brothers hes not home so we hooked it up to the other xbox 360 and it wont connect
1 Disconnect all accessories and wired controllers from the Xbox 360.
2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
Sep 29, 2011 | Microsoft Xbox 360 Console
Challenge WY05-11 heater has stopped working, the lights come on and the themostat appears to be switching on and off, is there a reset button or any other ideas?
there is a thermostat trip switch which has probably safety cut out. Unplug the unit from the mains power. Remove the three screws holding the control section to the radiator main body (two at the base - you will have to remove the wheel bracket to access the screws) and one behind a plastic cover in the recess at the top of the unit above the theromstat control. Gently remove the control unit. You will now see three sets of electrical connections to the unit main body. Select the top connection and between where the two wires meet the connection is a black bump. Gently press this and you will hear a click. The unit is now reset. Replace the control section to the main body with the three screws as above, replace the wheels and your unit is fully functional again.Hope that this helps. I have just repaired my unit in this exact way.
Dec 22, 2010 | Heating & Cooling
I have been having the exact same problem i can turn on the xbox with my controller. Then the lights around the controller telling you your position keep blinking i try the connecting buttons around the...
Try a known working controller in your system just to be sure that your original controller is not bad.
If the known controller works then you know your original is bad. If neither controller work then that means the controller ports are bad and the main board would have to be replaced.
Dec 01, 2009 | Microsoft Xbox 360 Console
Wiring Bathroom light/vent/heater switch with 3 separate controls
Wiring a bathroom combination vent, heater, light 3 way switch means more wires. In brief, you need to run two cables - one a two wire and one a three wire from the switch to the fan.
Incoming power will have white black and ground.
The two wire cable for the switch to the fan will have wht, blk, and ground.
The three wire will have red, blk, wht, and grnd.
The switch will likely have 2 blacks and a red coming from it, with two blacks and a red on one side, and a single black on the other.
The fan should have a red, blue, green, black, and white.
On the fan end: Group all green/copper grounds together and use a wire nut to fasten them together. Tape the nut to the wires.
There will be five white wires coming through. For ease of handling, using wire nuts, connect two on one nut and three on the other.
connect the blue to a blck. Connect one red to one black, and the other red to the other black.
The switch will have one red going into the 3 wire cable, a black going to the 3 wire cable, and a black form incoming power to the side opposite the 3 wires, and a blck going to the two wire cable.
There. Confused?
May 26, 2009 | Broan-NuTone FAN CONTROL SWITCH
My hard drive and midi controller wont work with usb
When you connect a hard drive and any other USB device to a 4 port hub you have to use the external power supply all the time. You may have fried the power pins on the USB port you used to connect the 4 port hub. If you can get the hard drive to work separately on the USB port, the 4 port hub may no longer be passing power from the laptop.
Nov 09, 2017 | Vestax Vci 100 Midi Controller
Directional Pad
honestly sounds like its the controller port either have to open it up and make sure everything is connect correctly around it or even blow some air into the ports to blow anything that might be blocking they come loose now and again over the years of use.
have you tryed it on the controller port 2 yet? if not try that and see if it works on that one.
Aug 20, 2008 | Sega Master System Console
Aficio 2022 connected to computer by parallel port
Hey Bubbabear,
I've got a Rico Aficio 2035
1.) It does have a hard drive installed (doc server)
2.) There is not a memory card installed
3.) There are no pinter buttons on the control panel
The rest of the scenario is the same...IE1284 Parallel port, but does nothing...
May 15, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
General Networking question
lets see here, your NVIDIA thing is for your ethernet port in your computer.
the wireless PCI adapter, is well, a wireless adapter, its used to connect your wireless, and a 1394 Net Adaptor Connection is basically Win2k/XP's way of telling you that you have a Firewire interface installed in your system.
so, if your going wireless, you dont need NVIDIA, and as your device manager shows that it has a red x on it, it shows that its disabled. as for everything else, i wouldent worry about it.
May 08, 2008 | Computers & Internet
Each unit needs a different code. If all the units operated from with the same code, when you switched on your TV the other units would also switch on even if you were not going to use them. The way to set up your One For All, is to find three different codes, then set up some of the functions such as the TV volume control to work common with all three units so you do not have to keep switching remote between them. To use the main functions on each unit, you will have to select them separately with the remote controller. Visit the One For All website, you will find it easily using Google. Have fun...
Dec 27, 2007 | One For All URC4110 Remote Control
Microsoft Xbox Console Logo
21 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
