Question about Dometic Rooftop RV Air Conditioner
Thermostat slow to turn AC compressor on. fan comes on but takes 5 min. before compressor comes on
    Problem Solver:
  • 5 Answers
Most a/c's have a 5 minute delay before the compressor turns on and they will do the same when changing from cooling or heating to cooling.
Posted on Jul 19, 2009
2 Suggested Answers
james3751
  • 614 Answers
SOURCE: Duro Therm. AC fan comes on but compressor takes 5 min. before
Compressor may have five minute time delay for compressor protection. Russ
I have a Dometic 15K roof Ac on my FW. After the AC reaches therm temp, the compressor and the fan turn off, but the fan starts right back up again and runs until you set the thermostat on off.
That is normal operation, only the compressor cycles, the fan stays running to keep air circulating for better temp control. Otherwise the rear of the space could get 5 degrees warmer than the front
Feb 23, 2015 | Dometic 459516 459516.XX1C0 Brisk Air...
Fan will come on but compressor wont kick in on wall unit ac
The start capacitor on the compressor is bad. Replace it and the compressor will run.
Jun 30, 2013 | Heating & Cooling
I have a digital Honeywell thermostat that has a blinking snowflake. When the thermostat is on auto mode it does not turn on. When I turn the thermostat to fan I can feel and hear the air blowing out of...
If the thermostat has a blinking snowflake then it is in time delay mode which sometime can take between 5 to 7 minutes before it will turn the AC and Fan On......Then it will go to a solid snowflake.
When you turned it to fan On it starts the Fan right away..... After the snow flake has went to solid check to see if the fan is running and then look outside to see if the Fan Blade is turning on the AC..... The fan blade comes on the same time as the compressor does. Then with the fan running hold your hand above the air stream above the AC and if you can noticeablely feel warm to hot air comeing out the Top then the compressor is running also. If the outside unit is not running I would check to make sure the Main Breakers are turned ON.... After the AC has ran for a few minutes feel the copper lines that go into the house the smaller line should feel warm to hot and the bigger lines with insulation on it should feel cool to cold and sweating with beads of moisture on it..... That is a quick test to see if the unit is working properly.....If you have a Thermentor and can Check the Temperature of the Return Air and the Supply Air .. You should have about 20 Degree F Between the Supply and Return........ 75* Return - 55* Supply would Equal 20* TD Across the Coil......
That is about all you can do to check on your own....... If the compressor is not coming on or the lines are not the temperature difference then you will need to get professional help for your Air Conditioning System..... Goood Luck Hope this Helps.........
May 14, 2011 | Heating & Cooling
RV Air conditioning not working properly
IF YOU HAVE A ENERGY SAVER SETTING ON TSTAT SET TO OFF THAT WILL KEEP FAN ON WHEN COMPRESSOR IS OFF. REMOVE LITTLE THERMOSTAT WIRE IN FRONT OF COIL WHERE FILTER IS , BE CARFUL NOT TO BEND IT IN HALF IT CONTAINS GAS IN IT MOVE IT SLOW ,ITS ABOUT COAT HANGER THIN OR HAS A BULB AT END . CARFULLY STICK IN WARM WATER GLASS TO SIMULATE HOT TEMP. SEE IF IT STAYS ON. NOTE BULB HAS NO WIRES ON PROBE. MOST ARE ALLUM. OR COPPER. IF YOU ARE NOT SURE WHAT YOU ARE STICKING IN WATER THAN HOLD BULB IN YOUR FIST CLOSED TO HEAT UP BULB IT WILL WORK THE SAME.
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
I have a Dometic rooftop Air conditioner in my RV When I turn it to low medium or high the fan run the same speed and when I turn it to AC it will run for about 5 min then the fan will shut off but the...
Bad fan motor I suspect The windings are bad causing the motor to over heat sending the motor into thermal overload. would suggest the replacement of motor. Good Luck on repairs
Dave
Sep 14, 2009 | Dometic Rooftop RV Air Conditioner
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
Fan cutting on and off every 5 mins
The only thing that is going to but the fan off is the thermostat. When the fan stops, immediately check the thermostat on the wall. See is there is power between the B terminal and the GH terminal. If none, then replace the thermostat. If there is, then replace the control board in the AC. That means that the fan relay on the printed circuit board is weak.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Fan motor slow on a/c
If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
  • OR
    This could the problem the with short circuit or defective component you need to check :
  • Compressor
  • Overload and/or relay
  • Thermostat (Open thermostat)
  • Burnt wiring
  • Bad selector switch
  • Capacitor
  • Good luck....
    Nov 11, 2008 | Heating & Cooling
    Running Compressor Intermittently
    replace the thermastat it has a bad set of contacts
    May 05, 2008 | Goldstar R8000 Air Conditioner
    Dometic Rooftop RV Air Conditioner Logo
    204 people viewed this question
    Top Dometic Heating & Cooling Experts
    Bill Long
    Donni Steen
    mike cooper
    Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
