Question about HP OfficeJet J4580 All-In-One Laser Printer
Printer 4580 tri color troubleshoot
The screen is saying [Print cartridge problem ] Tri-Color Refer to device documentation to troubleshoot.
i try reinstalling the cartridge, but it is still appearing the words
  • Paul Blessing May 11, 2010
    HI. Does it seem like you have enough ink? Is the bottom of the cartridge inked up when you pull it?
I think i run out of ink[or color.whatever the stuff in there is called]
so i will buy a new one and try to see if it fix the problem
Posted on Jul 19, 2009
Ink cartrige problem
This is error is common after a cartridge is refilled, in most cases it's because of "bad refill" and we can also say "dead cartridge". If possible, Please try the cartridge on another printer or try your printer with another cartridge. (i hope you know what tri color mieans = the color cartridge). Make sure the cartridge is not overflowing or leaking. Clean if possible, and never touch the print head, if you ever did so there's no way to make it work again. Hope this helps. Good luck Thanks for using FixYa.
Jun 01, 2010 | HP PSC 1510 All-In-One InkJet Printer
J4580 Print Cartridge Problem:[Tri-Color]Refer to Device Documen.
hi i dont have the tricolor cartridge in my hp 5610 and i want to work only with black cartridge and my printer says there is no cartridge on the left , is it posible to solve this problem and work with one cartridge only ? i can print but copy and fax doesnt work . thanx
Jul 27, 2009 | HP Officejet 5610 All-In-One InkJet...
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
Print cartridge problem : [Tri- color]
Printer display says: Print cartridge problem : [Tri-Color]. Refer to device documentation to troubleshoot. I can find nothing in the 'device documentation' to help me.
Apr 03, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP Solution Center Screen said: Cartridge Problem HP 901(Tri-Color Cartridge problem Lcd Printer said: Print Cartridge Problem; Tri-Color. Refer to device documentation to troubleshoot.
Have you tried to replace the current cartridge with a new one? It is not uncommon for even a new cartridge to be faulty, It happens sometimes.
Also, look in your printer manual for the procedure on how to run a nozzle/cartridge cleaning and alignment.
If that does not resolve it, take the cartridge out, grab some rubbing alcohol and some q-tips. Put some rubbing alcohol on a q-tip and GENTLY wipe the contacts on the cartridge AND on the contacts in the printer where the cartridge installs. BE CAREFUL! Make sure no cotton from the q-tip gets left behind on either.
Good luck and thanks for using the fixya forums!
Mar 27, 2009 | HP Officejet J4680 InkJet Printer
Problem of incompatible cartridge occure in my new J 4580
i had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
Feb 03, 2009 | HP J4680 Office Jet All-In-One Printer
HP OfficeJet J4580 All-In-One Laser Printer Logo
360 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
