Question about Hayward 100,000 BTU Pool Heater H100ID1 - Above Ground
Blower wont turn on - Hayward 100,000 BTU Pool Heater H100ID1 - Above Ground
    Champion:
  • 246 Answers
What blower be more expecific
Posted on Aug 19, 2009
Blower control
Check connector at the blower motor. The ground burns up in the connector. Also try this turn the blower motor on speed 3 then smack the bottom of the blower motor. If it starts blowing the brushes in the motor are worn out. Replace the blower motor.
Feb 01, 2014 | Buick LeSabre Cars & Trucks
I have a intertherm model e2eb-017ha the blower wont shut off i have to turn the braker off
One The blower relay is stuck in the on position. Two at the thermostat, fan switch should be set to auto. Set it on the blower wont quit.
Jan 29, 2014 | Intertherm Heating & Cooling
2001 2500 dodge heater control
When you say everything is fine, did you check the blower motor for power and ground with a meter ? The blower motor gets power from the relay, and the resistor and control switch provides the ground circuit.
Jan 19, 2014 | Cars & Trucks
Blower for heater will not turn on 2003 montana
There can be 2 solutions to this problem. The first solution is the blower motor resistor which controls the speeds of the blower as well as on and off. That is cheapest at around $20.00. The other is the switch assembly itself. Not sure of cost for that.
Nov 08, 2013 | 2003 Pontiac Montana
Blower motor wont turn off
It could be the blower relay. You would need to start at the blower motor and trace the wiring back to the relay to find out.
Jul 01, 2013 | Pontiac Bonneville Cars & Trucks
Heater wont turn on
So the blower doesn't turn on using any spped fan correct? This would most likely be the blower motor. Go under the dash on the passenger side and remove the kick panel and you should see the Blower housing. Remove the small bolts and verify nothing is in there or if it is seized.
Dec 06, 2012 | 1999 Buick LeSabre
LENNOX FURNACE WONT FIRE BREAKER WAS TRIPPED CAME ON FOR 2 MINUTES THEN SHUT OFF WITH BURNING SMELL AND WONT COME ON.
I would turn the furnace off, locate where the blower motor is, usually near the filter.. If you are capable,
reach in and try to turn the blower wheel. If does not
move, its possible the motor is bad.
If it is a multi-speed blower, change the heat spped to a different speed and see if the breaker trips, if it does then the indoor blower motor is probably bad
Jan 02, 2010 | Heating & Cooling
AC BLOWER MOTOR GETS HOT THEN TURN OFF.
I HAVE A 1998 CADILLAC DEVILLE,THE AC BLOWER MOTOR GETS HOT AND TURN OFF AND WONT TURN BACK ON UNTIL IT COOL OFF, WHAT IS THIS PROBLEM?
Jul 04, 2009 | 1999 Cadillac DeVille
Blower motor wont shut off
Check your blower resister in duct right in from of motor. These tend to burn out and short every once in a while
Dec 31, 2008 | 2004 GMC Envoy
Open Questions:
Hayward 100,000 BTU Pool Heater H100ID1  - Above Ground Logo
64 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
