Question about Samsung 2243SWX Monitor
I have the same problem on my new samsung 2234sw monitor.
I have the same problem, there is flicker in its native resolution of 1920px, theres no flicker when I lower the resolution but the quality of text sucks at lower resolutions.
Im using a vga cable from my video card to my monitor. Its an old nvidia 7 series card. Should I use a newer hd capable card and also use dvi cables instead of vga?
    President:
  • 1,179 Answers
The answer to your last questions are yes. Your old video card may not support so high a resolution and this is causing the flicker. Since you said lowering the resolution fixes the problem this would be the most obvious fix. You can get a new GTX 260 with 216 cores 896 mb RAM for about $165. This would allow you to play any games out there or watch hd without any problems. Just make sure your power supply is in the recomended range and has the required connectors for the card. You can get better than a 260 depending on your budget. Hope this helps.
Posted on Jul 19, 2009
Get this flsh out of my monitor.
Hi there.
If the screen flickers, make sure the display settings in Windows match the native resolution and refresh rate for the monitor. You can find the native resolution of a flat panel display in the specifications, in the printed material or on the box that came with the monitor. Some common native resolutions are 800 x 600, 1024 x 768, 1920 x 1080, and 1680 x 1050.
The most common refresh rate for LCD monitors is 60 Hz. This normally cannot be changed for flat panel displays using Plug and Play settings. However, if you are using special video software to increase or decrease the refresh rate, change the refresh rate to match the default refresh rate specification of the monitor.
STEP 1
To change the screen resolution and refresh rate settings in Windows, do the following:
- In Windows XP
See my tip on setting up the optimum screen resolution for Windows XP here.
- In Windows Vista (Same for Windows 7)
1. Click Start, and then click Control Panel .
2. Find the Appearance and Personalization area, and click Adjust Screen Resolution .
3. Move the slider bar until the screen resolution matches the native resolution.
4. Click Advanced settings, and then click the Monitor tab.
5. Select the Screen refresh rate that matches the default rate for your monitor (if it is not already selected).
6. Click OK, and then click OK again.
If you cannot select the native resolution or the native resolution is unavailable, continue to the next step to update the drivers for the graphics adapter on the computer.
You can get the latest updated video drivers from the video hardware manufacturer's Web site. Here is a list showing some of the video hardware websites:
Check for NVIDIA video driver updates at NVIDIA Home Page.
Check for ATI/AMD video driver updates at ATI/AMD Home Page.
Check for Intel video support and downloads, Intel Downloads. (If you have an Intel mainboard and are using onboard graphics).
NOTE: If you are using onboard graphics with a mainboard that is not manufactured by Intel, just give me the name and model number of your mainboard and I can try and locate the graphics drivers for you.
After updating the video drivers, go back to Step 1 and try to change the screen resolution again.
Note: If you cannot select the native resolution after updating the video drivers, the graphics adapter in the computer might not support that resolution and may need to be upgraded.
If after changing the resolution and updating video drivers the flickering persists then check the video cable connections. Unplug the cable and inspect the cable for damage. If the cable is damaged, replace it with a new cable. Try to use cables less than 3 meters (10 feet) long.
Monitors are sensitive to magnetic fields so have a look at the environment around the monitor. Speakers, florescent lights, fans, cell phones, radios, and any other electrical device can cause flickering. Temporarily move electrical items away from the monitor to see if they is producing a field that causes the flicker.
If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
To see if the video coming from the computer is causing the problem, temporarily connect the monitor to another computer. If the flicker is gone when the monitor is connected to another computer, then this means that the graphics adapter hardware on the first computer is damaged or might need to be upgraded to use the monitor. On the bright side at least it's not your monitor.
If however the flicker remains then the problem lies within the hardware of the monitor itself and is not a software problem. If you have bought this monitor fairly recently then I suggest you take it back to the place of purchase and have them test it. Some monitors carry 3 year warranty support so if you bought it within the warranty period specified by the reseller I suggest you see if you can get refunded or have them swop it out.
~Slasher_X
Oct 30, 2011 | Philips 190B6CB/27 19" LCD
Tip
Flickering LCD/CRT monitor screen or unstable image fix
If the screen flickers, make sure the display settings in Windows match the native resolution and refresh rate for the monitor. You can find the native resolution of a flat panel display in the specifications, in the printed material or on the box that came with the monitor. Some common native resolutions are 800 x 600, 1024 x 768, 1920 x 1080, and 1680 x 1050. To find out more about optimal screen resolutions see my tip on resolutions here.
The most common refresh rate for LCD monitors is 60 Hz. This normally cannot be changed for flat panel displays using Plug and Play settings. However, if you are using special video software to increase or decrease the refresh rate, change the refresh rate to match the default refresh rate specification of the monitor. To find out more about refresh rates see my tip here.
STEP 1
- In Windows XP
- In Windows Vista
Check for ATI/AMD video driver updates at ATI Home Page.
To see if the video coming from the computer is causing the problem, temporarily connect the monitor to another computer. If the flicker is gone when the monitor is connected to another computer, the graphics adapter hardware on the first computer might need to be upgraded to use the monitor.
If however the flicker remains then the problem lies within the harware of the monitor itself and is not a software problem. If you have bought this monitor fairly recently then I suggest you take it back to the place of purchace and have them test it. Some monitors carry 3 year warranty support so if you bought it within the warranty period specified by the reseller I suggest you see if you can get refunded or have them swop it out.
on Jun 08, 2011 | Computers & Internet
I bought a lcd monitor samsung syncmasterB1930 and it requires 1324*1068 screen resolution. i have installed the drivers for the monitors but still unable to get the desired resolution. is there any way...
The native resolution if this monitor is 1440x900 - i have no idea how you end up with that weird resolution. In any way it will not accept a higher resolution.
Nov 23, 2010 | Asrock 775I65GV...
Samsung SyncMaster 2233SW Monitor "Not
The "native" resolution of the monitor is the "optimal" resolution -- it looks best to use this resolution.
So, right-mouse click anywhere on your Windows desktop "wallpaper".
Click Properties.
Click Settings.
Move the "Screen Resolution" slider to the recommended settings.
Click Apply.
Click OK.
Nov 21, 2010 | Samsung SyncMaster 2233SW Monitor
I recently purchased and installed the P191W monitor, and now my pictures are stretched. I was told I new to get a new graphics card. What card should I get? Or can I just update the driver? I am running...
Find your monitor's native resolution, in your case it's 1440x900. Go to display settings (usually right-click on desktop and choose properties), go to settings tab and move the resolution slider until it shows 1440x900. Confirm, the screen should flicker for a moment and adjust - and you should be fine.
If there is no 1440x900 resolution available, then installing a monitor .inf file that came on a disk accompanying the monitor might help.
Oct 24, 2009 | Acer AL1916W 19" LCD Monitor
How i can fix my 21.5" computer samsung monitor, the display is slightly stretched
Set your screen resolution to 1600 x 1200, the native resolution of the screen.
Oct 11, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Can't display native resolution.
Dear Sir,
Better you have to try for once 1360X768 resolution. Its almost fits for Wide screen.
Please try for this.
Thanks
Sep 19, 2009 | Samsung 206BW Monitor
Monitor will not display in native resolution.
sounds to me like they replaced your vga board with another compatible one but not the same exact one I would call the repair facility that did the work and ask questions about how they repaired the monitor like if they used another vga board etc. hope this helps
Jun 19, 2008 | Samsung SyncMaster 245BW Monitor
New Samsung 245/bw monitor w/native resolution of 1920x1200
1.The resolution 1600*1200 is very good. why you need it 1920*1200 ?
2. What kind of samsung monitor do you have ? If is it LCD ... It doesn't suport that resolution ..... Mine, for example, 720N , suports only 1280/1024 . 17" .
Jun 07, 2008 | Samsung Computers & Internet
Resolution of the text
What is the resolution that you are running the monitor at? There are two possible reasons that come to my mind.
1. You are running at a non native resolution. Based on your LCD spec you should run it at 1280x1024 resolution to have very sharp text as you normally expect from LCD's. However if you have set another resolution (say 1024x768) the text is blurred and this is a known issue with LCD's, which unlike a normal CRT monitor will get blurred running at any other resolution :(
2. You have not installed the monitor driver, hence again this limits your resolution and windows only allows you to select a resolution that is non-native (Meaning since the driver file is not there the operating system may not allow selecting the native resolution the monitor should run at). You can find the driver file at the samsung site. Its a common driver file for all LCDs.
Dec 12, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Samsung 2243SWX  Monitor Logo
263 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
