SOURCE: Changing language from Spanish to English Nokia N73
1.You take another N73 from that you do your phone than you can cange your phone language spanish to english .
2.OK FIRST open menu and go to tools open, and go to settings open, after you open phone ther will be general ther phone language is there , then you can change. first you see the tools picture and settings picture and ther 1st oen is phone and 1st one is general and there 1st one is phone language
SOURCE: change language'
Press the center button... that is the menu button.. the highlighted one would be the gallery.. Gallery is the one that looks like a reel with a music note... from there press the left direction key once... this should be settings... this icon looks like a spanner.. press center key to select this...now from this new menu scroll down n select the one that looks like a phone with a spanner... use the down key to scroll.... on the 'Phone with the spanner' icon perss the center key.. The first option is always Language menu so press the center key on the first option... if all was correct you will get another menu in which again press the center key at the first option... Now if luck supports you, you will see a list of languages from which select ENGLISH {It will be in English :-)}...n voila
Lemme know how it works out mate
SOURCE: Nokia 6220c change language
as u can change the layout of the menu in this phone ill tell you buy the pictures
settings is the folder with a spanner
phone settings is just a spanner
general is at the top of the list
personalize is at the top of the list (blue and yellow faces)
in that list you have
display
standby mode
tones
themes
language
voice commands
select language (5th in the list)
phone language is the first in the list
hope this helped
SOURCE: change from chinese to english
hi
you need to go to
Menu>Setting>Phone>Phone language
Setting will have an Icon of Spanner
Phone will have an icon like a cell phone
you need to select language as English
the phone will ask to restart...select yes(left selection key
go to following link for your phone guide
http://nds1.nokia.com/phones/files/guides/Nokia_8800_UG_en.pdf
Hope this helps
Hi let me give you a hint.First try to Open Menu >> Setting by following the symbol >>Open Phone setting by following the symbol>>> inside the you'll see English.....Good luck
help pleaseeeeeee!!!!!
